GP final drive
Mikes d
09-18-2005 14:49:19
We are redoing our gp final drive, we put new races and bearings in, and have new chain case gaskets. But we are worried about oil leaking. Would it be beter to use A silicone type sealant that the gasket thanks
mikes d
09-18-2005 16:17:49
 Re: GP final drive in reply to Mikes d, 09-18-2005 14:49:19
And are there any better seals to use other than the felt seals
Mike M
09-18-2005 17:41:40
 Re: GP final drive in reply to mikes d, 09-18-2005 16:17:49
I have had good luck using the ultra type silcone along with a gasket,don't put it on very heavy and don't tighten it up all at once or the gasket can squeeze out.I go back later and retighten. I know someone who worked on one of the GP's and used regular oil seals they sized them up to fit the shaft then most of them wouldn't fit the housing right so they had to make a bushing/adapter to press fit in the seal to the housing.
