4020 synchro towing
Nylon
09-17-2005 18:31:35
Finally got my operators manual today. Answered alot of questions but I have a few more. It says to put synchro in tow position when towing. Does that mean to put it in one of the drants in neutral or does that mean to put it in one of the gears with the tow designation?
Also what does the nut that protrudes through the hole in the right side cover below the fuel injector do?
Thanks,
John
Bob
09-18-2005 09:49:00
 Re: 4020 synchro towing in reply to Nylon, 09-17-2005 18:31:35
When you tow it without the engine running, the the transmission pump is not running, and the gears on the transmission's top shaft spin on the steel shaft without any lube.
When the shifter is placed in the exact tow position, the 2 shift collars on the lower shaft are both positoned in such a way that the upper transmission gears are not driven, so there is no need for lube up there. The lower shaft is spinning inside the gears down there, but, assuming the tranny is full of oil, that lower shaft is submerged in oil.
If, for some reason, the tractor were to be towed with the engine running, the topshaft would be getting lube from the transmission pump, and towing won't cause any problems.
Tx Jim
09-18-2005 04:16:27
Nylon,if it were my 4020,I would only tow it out of line of traffic and I'd be calling a truck to haul it if I couldn't get it to move under it's own power. Towing without engine running is very risky!! Tx Jim
twopop
09-17-2005 20:17:11
to tow a synchro,the shift lever stays on the left side of the shift quadrant,half way between the 4-7 and 6-8 slots.any other position will weld up the top shaft.
if im thinking right,you are talking about the oil pressure adjusting nut.this is a not about 1 to 1-1/2 inches long
Nylon
09-18-2005 00:00:36
 Re: 4020 synchro towing in reply to twopop, 09-17-2005 20:17:11
Thanks 2pop.
