Delco-Remy Generator 1101390 7B26
Blksmok
09-17-2005 17:06:10
Anyone know what model of JD this generator is for?? Also, is it 6 or 12 volt?? Thanks!
55 50
09-17-2005 17:15:22
 Re: Delco-Remy Generator 1101390 7B26 in reply to Blksmok, 09-17-2005 17:06:10
It is a 6V and fits a late "B" S/N B201000 and later
P Browning
09-18-2005 03:25:56
 Re: Delco-Remy Generator 1101390 7B26 in reply to 55 50, 09-17-2005 17:15:22
55 5- -- Is there any reason why this generator would not work on a JD "H" tractor? The normal call-out for the "H" is Delco Remy# 1101377
55 50
09-18-2005 09:54:09
 Re: Delco-Remy Generator 1101390 7B26 in reply to P Browning, 09-18-2005 03:25:56
PB, I got my info from the same manual as Glen TX. It seeems that the 6V and RPM ratings would be the most important to be aware of. Many other specs are listed in SM-2029. Certainly wouldn't hurt to try a generator in an application that Deere didn't list as long as your voltage numbers are the same.
Glen in TX
09-18-2005 09:07:50
JD SM2029 charts shows it was only used on B 201000- & later. Might fit others? May be different mounting ears or length? I don't know. It only shows the 1101377 was only used on all Hs. At least 32 Delco generators used on letter and number series tractors, combines, power units, and balers of that era so.. lots of mix and match.
P Browning
09-18-2005 10:54:28
 Re: Delco-Remy Generator 1101390 7B26 in reply to Glen in TX, 09-18-2005 09:07:50
Thanks to both Glen & 55 50 -- So often gets far enough into the forrest that trees aren't seen. Thanks for waking me! I have been so intently focused on electrical function in the last few weeks that I tended to overlook the physical attributes. I am glad to be back!!
Blksmok
09-17-2005 19:10:46
55 50..... .Thanks for the quick info. It was with a JD70D I bought, but I figured it was for a letter series JD as it doesn't have the cooling vanes on the pulley.
