B running hot
Kurt_JDB
09-17-2005 13:23:53
I just finished rebuilding the Carb on my "51 B. While I had the carb off, I drained the coolant out of the system, (which is the first time I have done that since I got the tractor), and removed the upper and lower water pipes, and cleaned and painted them. The system sat dry for about three weeks.
Today I got it all back together and started her up. Much to my suprise the engine heated up in about 5 min. After 10 min. she was running about 200 degrees. Normaly it takes about 20 min to heat up to 190 with the shutters closed.
I ran around, going up and down hills for about 45 min, but the temp. stayed at about 200 with the shutters wide open.
When I filled the system, I put in 2 gallons of antifreeze, then two gallons of water, then another gallon of antifreeze and then topped her up with water. Should I have mixed it up?
Any ideas about why she is running so hot just idleing around?
Thanks,
Kurt
buckeye al
09-19-2005 14:01:46
 Re: B running hot in reply to Kurt_JDB, 09-17-2005 13:23:53
Agree.... need to mix em up.
I first encountered this with an H because it takes an H FOREVER to warm up not under load. Not expecting it to be warmed up in less than a half hour or so at 1/4 speed, no load, I was VERY surprised to see it boil over in about 10 minutes! I shut it down & inspected everything. Found nothing wrong so cautiously re-filled it & tried again. Never had the problem again. Have come close a time or two but knowing now what causes it, no trouble.
As James says, the ethylene glycol is heavier than water. Specific gravity being about 1.097 as opposed to water's 1.0 and just as he says, it lays in the lower pipe & the block like a big fat slug. In addition, the amount of heat needed from the engine to warm a gallon of antifreeze 100* is less than for a gallon of water so each gallon of that slug warms up more quickly than would a gallon of water.
Saw the question, why doesn't is settle out every time we shut them down? That's because the ethylene glycol and water don't form a MIXTURE, they combine to form a solution. One is in a sense dissolved in the otehr and they're quite difficult to separate once in solution. If you put a quart of oil & a quart of water together in a gallon bucket & stir them violently, they'll mix together and may even appear to become some sort of slurry but it is still a MIXTURE. As soon as the mixer (whatever it be) is turned off, they'll promptly begin to separate. Do the same with a quart of oil and a quart of gasoline & they won't separate because they combine to form a solution instead of a mixture.
In a thermo siphon cooling system, until the ethyene glycol & the water form a single solution and thereby become a substance of uniform specific gravity, the system is likely to boil over (a violent mixing action) before the coolant circulates and cools the engine.
I usually dump in a half a jug of antifreeze then fill that jug back up with water & pour it all in. The next jug I pour half off into the first jug & then fill 'em both with water then dump into the radiator. Keep doing that 'till full & you won't have trouble.
If your tractor has a water pump, you will never see these difficulties.
Kurt_JDB
09-19-2005 17:20:06
 Re: B running hot-update in reply to buckeye al, 09-19-2005 14:01:46
buckeye al,
Much thanks to you and all the other who replied to my overheating problem.
I thought you might be interested in what happened after I had drained and flushed system, and then remixed the antifreeze and water. First I drained the coolant into five gallon buckets, and poured it back and forth until all was mixed properly.
Then I ran a hose through the fill tube, and ran water through the system for about 10 min. Then I attached the hose to the block drain, and back-flushed. I then (as per JD service manual) filled the system with a solution of water and washing soda (sodium carbonate) at the ratio of 1 gallon water to a pound of washing soda. and ran the tractor up and down hills for around for an hour.
Much to my horror, she heated up quickly again, (15 min) went over 200 pegged at 240, and then settled at 190. After an hour, I let her cool a bit, drained the system, flushed with water again, and filled with the mixed water/antifreeze solution.
The next day I started her up and drove around again. She warmed up normally, and never topped 170 with the shutters open. So all is well again.
I do think that premixing the antifreeze and water must be done in a thermo-siphon system. I am also thinking that the water/washing soda solution must hotter before it expands and starts circulating.
Kurt
buckeye al
09-20-2005 13:29:40
 Re: B running hot-update in reply to Kurt_JDB, 09-19-2005 17:20:06
Funny stuff that water! It's everywhere & we don't think much about it but it's kinda different stuff!
Glad your B is doing well now!
Kurt_JDB
09-17-2005 19:36:31
Thanks everybody for the comments. I will try draining and remixing and flushing for good measure.
Kurt
RayP(MI)
09-17-2005 18:35:42
Done the same thing - Like the others say, drain the system, mix the water and antifreeze and put it back in.
James Nauert
09-17-2005 18:24:20
You most definitely have to pre-mix your antifreeze and water. In a thermo siphon system that pure anti freeze will lay there like a slug it will take more heat to move it. I did the same thing once with a H i had wont do it any more.Drain it then remix it.
55 50
09-18-2005 18:25:12
 Re: B running hot in reply to James Nauert, 09-17-2005 18:24:20
OK. Explain this to me. If you really have to mix the water and antifreeze before pouring it into the radiator, what is to keep the antifreeze from separating and settling out and causing this heat problem every time you shut the engine off and it cools down? I agree with Pat Browning that mixing is not necessary!
55 50
09-18-2005 18:28:49
 Re: B running hot in reply to 55 50, 09-18-2005 18:25:12
I forgot to add that I have pure antifreeze in my 50 and it cools just fine, never gets above 170. Maybe that's irrelevant, but I wanted to add reinforcement to PB's entry.
Duane Larson
09-18-2005 19:35:45
 Re: B running hot in reply to 55 50, 09-18-2005 18:28:49
55 50,
Your 50 has a water pump, which forces circulation. The problem is with a cooling system which depends on thermosiphoning to move the coolant. The specific gravity of pure antifreeze is higher than that of water, and it does not rise as well as water when it gets hot. Premixing allieviates the problem a bit, but pure water provides the best thermosiphon action. I doubt pure antifreeze would thermosiphon.
ELI
09-17-2005 18:19:57
Kurt, when the gauge is reading 200 degrees is the radiator tank hot? I can't believe that the hole system is rising to 200 that quickly. My best guess is the system isn't circulateing. This can happen if their is an air pocket in the system. I'd let it sit overnight. Check the level the next day and try it again. If it heats up again then you'll need to drain it and run a garden hose through it any where you can. Then procede with the vinegar method. Good luck, Eli
Kurt_JDB
09-17-2005 19:49:25
 Re: B running hot in reply to ELI, 09-17-2005 18:19:57
Tank was cold, and bottom pipe was cold when gage read 200+. Then only one side of radiator started to get hot. After some time, bottom pipe slowly got warm along its length. I'm thinking I should have mixed the antifreeze.
Kurt
P Browning
09-18-2005 11:08:25
 Re: B running hot in reply to Kurt_JDB, 09-17-2005 19:49:25
Kurt -- you have some serious blockage in there. And of course you will need to drain the radiator to resolve it. Your grief IS NOT a result of failing to mix. It wouldn't matter anyway if the two fluids mixed or not. You could have pure water or pure ethelene glycol -- either would cool the engine, and surely one isn't going to stand in the way of the other's circulating!
For all who are reading this post -- if you drain the coolant from an old tractor -- not knowing how long it had been in there -- the wise thing to do is to flush right then! Don't let some standing goop go hard on you. There is an outside chance that the only way Kurt will get at this beast is some teardown. Its most likely a stopped up radiator core -- but there may also be some junk in the engine block as well. Lots of junk that may be in the engine can be cleaned out by removing the upper & lower hoses & opening up the drain, then flushing directly into the block and out of the head. You can back flush too.
Years ago we had a plastic turkey baster in the kitchen. The rubber squeezer ball rotted off -- I saved the tube part. It adapts right well to the end of a garden hose using a male hose connector ring to secure it to the end of a hose. With that little puppy, I can shoot a stream of water "for a while." It acts like a water jet. Perhaps this sort of thing would be helpful.
Gosh -- I have rattled on & on here -- I wish for you to be blessed my friend. You are a very wise man to be concerned with the heating -- and I just know you will soon have your arms around it all. (Pat B)
MACE
09-17-2005 17:30:27
I would tend to lean toward the idea of things drying up inside the radiator etc. I have a 1950 John Deere B that runs around 200 to 210 all the time (degrees not mph). I believe, from what I have been told that it will run cooler. When I purchased the tractor the coolant system was open to air and everything else imaginable for a long time. I have seen dry scale deposits brake off and fall out of radiators due to being exposed to the air for a while. I believe that is what is going on in my tractor. I suppose I need to clean it and flush it. While running it has never boiled over and I can touch the lower water pipe by hand and tell a big differnce in water temp. I know the water is circulating. Maybe if it were circulated faster the temp would drop due to less of a restriction in the coolant system.
MY TWO CENTS...
MACE
55 50
09-17-2005 17:09:50
I disagree that you need to mix the solution before putting it into the radiator. It may be a long shot, but I'd check the temp with a known good gauge. There is some possibility that the original gauge went bad. Or as another message said, the loose scale could have plugged the area where the temp gauge probe is and there is little or no circulation there.
old
09-17-2005 14:39:02
My guess would be is that you should have done a flush of the cooling system when you had it drained. Sitting like that has probably got things floating around in the system and clogging things up. I'd flush the system with vinagar and then flush with water and then refill with the antifreeze.
JD @ Antique Acres
09-17-2005 14:10:05
When adding coolant you need to pre mix it. This type of system doesn"t mix the solution as a system would having a water pump. As for the temperature 200 degrees is more "normal" that not. These engines run best at 200+
Dave Brennan
09-19-2005 02:03:41
 Re: B running hot in reply to JD @ Antique Acres, 09-17-2005 14:10:05
Restored a 1937 BO About 10 or 12 years ago and did not mix the antifreeze. Did it about the same way as you discribe. The first time I started it I was supprized at how quickly it heated up. (Whoe Baby!! whats wrong now!) I relized my mistake right away and shut the tractor off, drained the antifreeze, mixed it. After it ran fine and was no longer a problem. Raked hay with it this year in 90+ degree weather and it ran about 190 degrees. Experience is the best teacher I would say.
P Browning
09-19-2005 21:43:00
 Re: B running hot in reply to Dave Brennan, 09-19-2005 02:03:41
Actual testimony is hard to beat. It would appear that one can "block" a system with antifreeze solution, now that I read some of the parts of this thread. It is an issue that at least merits more study. I must say, however, that one has to be pretty deliberate to so completely fail to achieve a sufficient "mix" to begin with. I have always ignored the issue, beginning with water first and then the antifreeze compound -- and somehow was blessed, every time, never to have had Kurt's problem. Perhaps "water-first" is the key. But in reading his report carefully, I am still not fully convinced -- at least not in his case anyway, that ethelene glycol blocking was his total problem!
Kurt_JDB
09-20-2005 16:37:40
 Re: B running hot in reply to P Browning, 09-19-2005 21:43:00
Hi Pat,
I can think of an experiment to test your theory about the order of filling a system with antifreeze and water and whether it will mix or not. Theory is that if you put the heavier liquid (antifreeze) in the system first, the water will not mix with it but will float on top. However if you put the water in first, the antifreeze will mix in as it sinks through the water.
The experiment is as follows:
Take two tall glass vials (test tubes? glass cigar tubes? tall glasses?). In the first one, fill half with antifreeze, and then -very slowly- fill the rest with water, using an eye dropper or something.
in the second one, fill half with water and then slowly add the antifreeze. It should be obvious looking through the glass to see if they are mixed or not.
Kurt
