Fuel pump for 3020 gas
Lincoln
09-17-2005 09:13:39
I had to replace the fuel pump on my 1966 3020 gas tractor. The parts guy at the dealership said the older style pumps with the glass sediment bulb on top are no longer available and the replacement is a plain automotive looking fuel pump. I took the one he had and it works fine. Do I need to put a fuel filter in the line somewhere since I no longer have the sediment bulb?
buickanddeere
09-17-2005 09:50:51
 Re: Fuel pump for 3020 gas in reply to Lincoln, 09-17-2005 09:13:39
Robert's Carburator sells a couple of different sediment bowls with shut off valves. I've adapted them to 110 garden tractors and cranking engines on diesel two cylinders. They look factory installed.
