2010 Gas Engine Rebuild
TDK
09-16-2005 21:53:20
The catalogs I've looked at so far only show oversized piston/ring kits for this tractor, no sleeves. Parts manual shows the sleeve assembly. My question is, can the sleeves be bored & if so, how much ? Can the sleeve assy. be bought new ? Thanks for any info !
msb
09-16-2005 22:02:35
 Re: 2010 Gas Engine Rebuild in reply to TDK, 09-16-2005 21:53:20
Is it a gas engine?I think Deere discontinued supplying the sleeved deck assembly.Its the same as a 145 CID gas engine used in a 45 combine if you need a used one.The design was not one of Deere's better ideas.The deck had a bad habit of cracking where the sleeves attached to the deck.Be very careful when pulling the assembly as it is easy to damage or crack them.Yes, obviously the sleeves can be bored.Your machine shop can tell you how much they can bore it. I believe the later 165 cid combine engines will bolt right up.
TDK
09-16-2005 22:38:12
 Re: 2010 Gas Engine Rebuild in reply to msb, 09-16-2005 22:02:35
msb, I see you stay up late also ! Thanks for the reply. It is a gas engine. Currently it's stuck, on two cylinders I believe. I was mainly curious, tractor doesn't belong to me, as to what the owner may be looking at as far as cost. Rebuild or replace engine. Maybe get lucky and just a set of rings and bearings.
