4020 hydrolics problems
idontno
09-16-2005 20:49:04
Hey Guys.I have a 4020 and the hydrolics on the loader are getting jumpy.The curl on the bucket won"t stay up.When digging and curling the bucket up ...it( bucket) wants to seep down.It will go all the way down if you don"t keep it up with the control.Lift seems to work good.Pump making a little noise but not bad.I guess I wanting someone to tell me it not serious...Can anyone give me some ideas.I am going to take off hoses on back and change them to see is it might be that....But other than that I"m lost..Help!!!
donmyeil
09-17-2005 06:58:49
 Re: 4020 hydrolics problems in reply to idontno, 09-16-2005 20:49:04
Easy way to eliminate the cyl.s is to put a load in the bucket then just turn off the hose couplers. If the bucket settles then the cyl.(s) is bad. if it doesnt settle suspect the thermo relief valve on the end cap of the valve box. Might also need to rebuild the valve box. I am assumeing you are useing the tractor valve boxes.
msb
09-16-2005 21:34:02
Switching hoses is a good place to start.IF that doesn't do it then suspect you have a bad bucket cylinder.If it does then it is probably in the valve itself.
idontno
09-17-2005 15:39:01
 Re: 4020 hydrolics problems in reply to msb, 09-16-2005 21:34:02
Today I took the hoses off and switched them around..It still drops when I curl it.So Does this mean that I have a bad cylinder? Another question.How do I tell which cylinder it is?
No visible leaks on either cylinder.This is a GB loader and it has the originals cylinder on it. I guess it time to wear out after 40 some years...
msb
09-18-2005 13:49:35
 Re: 4020 hydrolics problems in reply to idontno, 09-17-2005 15:39:01
Best bet would be rebuild both cylinders since they are that old.You could unhook each one individually to determine which one bad only to have the other one go bad a few months down the road.Parts don't cost very much and the repair is an easy one.
