1947 Radiator
Randy Trentham
09-16-2005 18:46:00
I have a new radiator core. The top and bottom of radiator have been painted and now I want to reasemble the radiator. Radiator is out of tractor. What is best gasket sealer to use and what is best step by step process to use. I have all new bolts and I"m ready to reasemble everything. I sure don"t want to mess up now. Thanks for your help. Randy
Mike M
09-18-2005 17:48:58
 Re: 1947 Radiator in reply to Randy Trentham, 09-16-2005 18:46:00
I have done several radiator cores and have always made my own gaskets from a thick gasket material either paper or cork rubber can't remember if it is 1/16" or 3/32' ? I usually don't use sealers as most don't work with antifreeze they have some out now that are made just for that. I have also had to have some of the tanks resurfaced to clean up the pitting.
DickD
09-16-2005 21:15:42
I did one on a late model A. I cleaned the surface on the tanks THOROUGHLY. Then I took a tap and cleaned the threads where the bolts thread in. I used just a small amount of blue silicone. It worked very nicely. I didn't have one leak and after 6 years it is still OK
