4020 Rockshaft supply return
Nylon
09-16-2005 16:38:56
Someone replaced my rockshaft supply line with a hose. I didn't think much about it until I was fixing battery boxes. The return from rockshaft is a fairly big steel line. The supply line is a 1/2 inch..same size as loader working lines hose. The fiting on the supply is an elbow that the 1/2 inch rubber threads on to. Is this enough supply juice? It is hard to say for sure but that elbow fiting mite turn into some sort of thread adaptor to fit a bigger hole. It is flush with the tractor caseing. Do I need a larger supply line and fiting here?
Also....important too. Does the rockshaft return line go to charge? Anyone with a diagram confirm if this goes back to charge or dumps into sump? Mine is a 68 diesel.
Any info appreciated.
Thanks,
John
HTR
09-17-2005 00:15:06
 Re: 4020 Rockshaft supply return in reply to Nylon, 09-16-2005 16:38:56
The one half hose and fittings are big enough to supply the rockshaft. The return oil from the rockshaft goes to the filter relief valve housing, combines with transmission pump oil, and returns to the inlet side of the main pump. The return oil, from the rockshaft control valve dumps into the center cavity of the rockshaft housing. There is a plate on the bottom of the housing, and an Oring on each end of the rockshaft, if these leak the oil will be dumped to sump, and two or three cycles of the rockshaft, it will start chattering, and be very slow. If the clutch peddle is held down, with a leak in the housing, you will loose all hydraulics. The only functions, on the tractor that don't return to the inlet side of the pump, are the differential lock and brakes. If all valves are functioning properly and no internal leaks, you should be able to hold the clutch peddle down, raise and lower the rockshaft continually, and steer from lock to lock continually for ten minutes before losing hydraulics.
msb
09-16-2005 21:45:37
IF you are talking about the line on the right side of the transmission case that goes to a fitting near the filler neck,it is the supply line from the pump.The rockshaft return dumps internally.If you have adequate 3 point function,I would not worry about it.The line only serves the rockshaft function.
Nylon
09-16-2005 23:34:23
 Re: 4020 Rockshaft supply return in reply to msb, 09-16-2005 21:45:37
MSB,
Thanks for your help again. Yes it is a line from the brake pedal outlet on right side that goes back to near the filler neck and near the top. It is now a rubber 1/2 inch line. Which ia also going to be my loader supply line which is why I am concerned as to it having adequete supply.
There is a large line returning from the left side high and then down to just behind the filter cover. I thought that it was the rockshaft return. If it isnt that return what does that line do?
I managed to get the wheels unstuck and moved out on the axles so that I could wire brush and sand out the lower cab. With the wheels moved out I was able to lift off the battery boxes and learn a bit more about what goes on back there. With the battery boxes off I could see that large line. So that is why I am asking.
I had lost my starter button and was jumping the solenoid to start it. I found that nuetral safety wire and found that it was off and the connector was toast. I clipped the connector body off and custom crimped the spades so that they stuck pretty well to the safty switch. What a luxury being able to start it in the cab :]
Thanks Again,
John
