Attn Pullers
DickD
09-16-2005 14:20:46
The prettiest pull I ever saw was at a dead weight pull where a guy had a late model A weighing 8000lbs with dual wheels. He would throttle up about one third and push the clutch in bringing the front end up about a foot and guided it with his brakes and finally won the contest. Prettiest job of driving I ever saw. Sure would like to hear some other experiences some of you have had.
Chances R
09-18-2005 09:29:45
 Re: Attn Pullers in reply to DickD, 09-16-2005 14:20:46
third party image
Here is a picture you may like. Taken in 1973 its my 1918 30-60 Aultman Taylor
DP
09-16-2005 20:35:03
That was known as a stump pull here. Seems every area had a little different rules. In this area it took 3 foot to qualify as a pull, and 27 1/2 foot to be a full pull. then the puller would go to the other end of the sled and pull the other way. The puller had the option of telling them how much weight to add and then the fun started again. Around here the pull would start at maybe 5 PM, and sometimes end at 4:00 the next morning. The pullers could pick their spot to pull, so the sled would be dragged to that spot for each puller. By the end of the pull they had a D-7 CAT dragging the sled between pullers. It was a lot of fun, but also a lot of work throwing those salt bags.
mike brown
09-16-2005 17:46:33
If a dead weight pull is like a stone boat we used to have one nearby that the FFA put on as a fund raiser and it was a blast. It was pre 1960 only, by power rating (no hot rods)and 100'timed pull so it was kind of a race. They had enough weight on the boat that you had to go in a pretty low gear so there were no speeding tractors. The topper was that there was a soft spot near the end of the track where the boat would dig in a bit so a lot of tractors would lug down and lose time or not make 100'. It was fun to see which tractors had snot in reserve to pull through the bog at the end of the track. The John Deeres excelled at this type of pull especially the diesels. We could back out the rack adustment, spool up the fly wheel for extra power at the start and let the smoke roll. I miss that pull. Mini Moes were also very good.
DickD
09-16-2005 19:27:36
 Re: Attn Pullers in reply to mike brown, 09-16-2005 17:46:33
Thanks Mike. Sounds like a fun time. You are definitely talking about the right era when you mention the term "stone boat."
