4020 Knock
JDJames
09-16-2005 10:45:23
I'm going to look at a 4020 Diesel in the next few days. Here comes the problem. The seller said that the engine has a knock, but the price is really good. What could be causing this? Thanks in advance!
buickanddeere
09-17-2005 12:00:10
 Re: 4020 Knock in reply to JDJames, 09-16-2005 10:45:23
Price a re-man engine from Deere and deduct that off the going price for 4020's. Allow for a clutch and seal job too when the tractor is split.
Pete/ME
09-17-2005 02:41:16
What I'd do is figure the cost of an engine rebuild from the selling price. If the rest of the tractor is cherry, you'd do O.K. no matter what.
msb
09-16-2005 21:50:40
Don't give more than what you would for a pig in a poke beacuse that is what you would be buying.It could be a REAL money pit.Good advice below.Know of anyone who works on Deere tractors that you could get to listen to it?
Mike M
09-16-2005 10:57:11
Something as simple as a loose waterpump bearing,loose hyd. pump coupler to the major stuff like rods and main bearings.Seller may know more than is letting on as that's why it's for sale ?
G/MAN
09-16-2005 10:56:49
Could be a main or rod bearing. Could be a wrist-pin bushing that's bad. Could be a faulty nozzle not atomizing the fuel correctly, causing incorrect combustion. Could be a scored/scuffed piston/liner, etc. It's also possible that the hydraulic pump coupler is completely junk, and that's where the noise is coming from. Hard to diagnose or speculate on just what it is without seeing it and hearing it.
mike brown
09-16-2005 17:51:02
 Re: 4020 Knock in reply to G/MAN, 09-16-2005 10:56:49
Go into this with eyes wide open! Is it a good buy if you have to drop a rebuilt engine in it cause you may have to.
