jd # 5 Mower
jossette
09-15-2005 19:50:31
can a guy still get parts for this?????
Mike M
09-16-2005 07:53:33
 Re: jd # 5 Mower in reply to jossette, 09-15-2005 19:50:31
The main stuff,knife,guards,pittman our local TSC has in stock.
Glen in TX
09-15-2005 23:25:05
Yes, Parts available from JD and many aftermarkets sources also. #5 Operators Manual OMH10156 and PC-466 Parts Catalog available from JD at 800-522-7448.
Bob
09-16-2005 07:51:02
 Re: jd # 5 Mower in reply to Glen in TX, 09-15-2005 23:25:05
That operator's manual and the parts book are priced at $30.00 EACH from Deere TechPubs.
Within the last year, I picked up an original owner's manual (OM-H10-250), which has a parts book in the back section, on ebay for about $10.00. A bit of a savings, if you can find one of those!
Glen in TX
09-16-2005 09:22:42
 Re: jd # 5 Mower in reply to Bob, 09-16-2005 07:51:02
Like Bob said you can sometimes find original manuals for less in ads here or ebay. There were different versions of the operators manual also. The one I listed was probably the last one JD printed for the #5. Just get a manual that is for the #5 mower. I have another version OM-H10-156 operators manual for #5 Caster-Wheel Power Mower. Just a different version and it shows operation, maintainance, assembly, accessory options, and charts and illustrations for many hookups to several makes and models of tractors.
jossette
09-16-2005 05:17:13
thanks fella
Bob
09-15-2005 20:07:29
Yes.
Specifically what do you need?
jossette
09-19-2005 16:13:57
 Re: jd # 5 Mower in reply to Bob, 09-15-2005 20:07:29
I need the hydraulic hookup tabs. I am converting the hand raise to hydro..
55 50
09-20-2005 09:49:08
 Re: jd # 5 Mower in reply to jossette, 09-19-2005 16:13:57
You can usually find those at swap meets for very reasonable prices. I saw a set attached to a model 50 tractor (without the mower!) earlier this summer at an implement dealer in North Dakota. Let me know if you still need them and I can email the dealer name and phone #.
jossette
09-20-2005 16:18:43
 Re: jd # 5 Mower in reply to 55 50, 09-20-2005 09:49:08
thanks fella
I will keep you in mind...
55 50
09-21-2005 20:54:37
 Re: jd # 5 Mower in reply to jossette, 09-20-2005 16:18:43
Shucks, I am in error. The brackets I saw are the quick-tach brackets that go on the drawbar sides. I wasn't thinking correctly. Sorry
jossette
09-22-2005 17:49:17
 Re: jd # 5 Mower in reply to 55 50, 09-21-2005 20:54:37
not a problem
