Another JD B Oil Question
Mixman
09-15-2005 18:50:47
I do not have oil splashing inside the gov housing. The fan drive gears are dry. This is a 37 model B #40928. I have oil pressure. Is the oil feed from the pump for the gauge only? I have the gov off of the tractor and the inside of the housing is bone dry. I can't find any literature at our local JD store, it either took a walk or got tossed.
Lee B
09-15-2005 20:27:35
 Re: Another JD B Oil Question in reply to Mixman, 09-15-2005 18:50:47
There should be a very small hole at the bottom of the well of where the oil pressure gauge fitting screws into the governor, so no, the oil fitting is NOT just for the guage. The little hole should shoot oil straight forward onto the governor shaft between the fan gears and the right governor shaft bearing. From there, that oil gets slung around to the fan gears and right governor shaft bearing. The hole is at best 1/32" in size so it would tend to plug up.
Mixman
09-16-2005 18:48:06
 Re: Another JD B Oil Question in reply to Lee B, 09-15-2005 20:27:35
Thanks Lee, and everyone else. I found the oil journal. It was really plugged. I know that the fan drive was a problem with them and now I know why.
Dave Brennan
09-15-2005 19:47:57
It has been a while since I have been in one of these goveners but it seems to me that the cam gears are suppose to pick the oil up and fling it in a trougth off of the govener drive gear and then the oil is distributed to the bearings and though a pipe to the rocker arms from there. Check to see if there are holes pluged in the trougth. I can't remember but there may be some passages that lead to the bearings from the oil pressure line?
billyiron
09-15-2005 19:35:07
theres another pressure outlet into the govenor housing, now that you got the housing off spin the flywheel, to see where the oil comes up thru in the crancase, might be plugged, or the tube in the crankcase is cracked off,or govenor house passage is plugged, this happened to one of my As,the bonehead that worked on it put the gasket over the oil passage between crankcase and gov housing,,,billy
Mixman
09-15-2005 19:48:14
 Re: Another JD B Oil Question in reply to billyiron, 09-15-2005 19:35:07
Is yours an unstyled B with the oil tube to the valve cover? Approx where is this other feed? I can get oil flowing thru the line to the gauge by spinning the flywheel by hand.
jd b puller
09-15-2005 19:31:46
Not sure about the unstyled. On the 41-46 models theres a line that goes from the oil pump up to the governor housing. Kind of a big line, close to 1/2" diameter. On the later ones, theres a line that plumbs into the casting below the governor. Take the crankcase cover off the top and see if there is a line going straight up from the oil pump. Hopefully the U/S is close to the later ones...
Dave Brennan
09-16-2005 18:33:24
 Re: Another JD B Oil Question in reply to jd b puller, 09-15-2005 19:31:46
I think Lee B is right. I looked in one one of my old manuals today and it clealy shows a passage that is drilled from the oil pressure gauge into the govenor housing.
