4020 cant get in gear
Mark Johnson
09-15-2005 17:10:30
I have a 71 4020.The tractor sat for 2 months and now i cant get in gear.I hooked up a switch to the solenoid and can get it to start in gear but the clutch wont do anything, their is resistance but wont engage.How long should i drve it to break it loose?I tried bumping it in several gears to try and break loose no luck.I really dont want to split tractor to break plate free.Any suggestions?
WTW
09-16-2005 09:41:30
 Re: 4020 cant get in gear in reply to Mark Johnson, 09-15-2005 17:10:30
Mark, Not to tell you what to do but, if simple efforts driving it and such does not knock it loose. Take it somewhere and have it split. Because it may have a bolt busted as previously suggested and abusing it will just cause additional unnecessary damage. If tractor is not equipped with a loader or brackets of such it not that hard or time consuming to split if the person knows what he is doing and has the stands to do so. Not to brag but I can have the flywheel of that 4020 tractor in the back of a pickup truck in 45 minutes. These tractors were a walk in the park to split. A afternoon and you back in business. DW
msb
09-15-2005 20:37:44
Do you mean it won't disengage? If so I would suspect an operating bolt has broken since you feel resistence with the pedal.Remove the imspection plate and look for a double nut in a short piece of bolt.IF one is boken then the tractor will have to be split.It was a very common thing early on with 4010s and early 4020s.
G/MAN
09-16-2005 07:34:50
 Re: 4020 cant get in gear in reply to msb, 09-15-2005 20:37:44
That's also possible, but so is the chance that the clutch is corroded and "stuck". Apparently Deere realized this could happen, as I was reading my 5020 Operator's Manual the other night, and they suggest blocking the clutch pedal in the disengaged position when parking the tractor for long periods of time.
G/MAN
09-15-2005 17:21:48
How about hooking a bunch of tarp straps to the pedal and letting it sit for a while. Maybe a continued pull on it over a period of time will make it pop loose. You could also take the inspection cover off the bottom of the clutch, and see if you can roll the flywheel around to where you can CAREFULLY and GENTLY get in there with something fairly soft and tap on the edge of the disk, or on other areas of the clutch assembly. Maybe it will come loose. Or, when you have it moving in gear, depress the clutch pedal as much as you can, keep some pressure on it, and tap the brakes pretty hard with the pedals locked together. Maybe something of a shock load coming back through the tranny will pop the clutch loose.
Mike M
09-16-2005 04:58:39
 Re: 4020 cant get in gear in reply to G/MAN, 09-15-2005 17:21:48
GMAN is right on track,try to get in somewhere with a screwdriver with the clutch pedal wired down and loosen the disk.I was able to do this on a 3010 The only place I could get in was a very small opening in the flywheel behind the plate that comes off to check the timing.I also had very good luck with a 850 c.u.t. got it going in high gear by shifting trucker style on flat level groung hang on good and jamb 1 brake pedal,this will shock it loose 2 brake pedals does not do much.Learned this trick over on the 8N ford forum.
