JD 45 combine cab?
Ian T
09-14-2005 21:22:31
I just pick up a 45 combine, later round back version. Does any one know if JD put on a factory cab on these units. Mine doesn't have a cab but curious to know if there was a cab aviable and if it is a direct bolt on ?
Dirtjockey
09-15-2005 18:31:00
 Re: JD 45 combine cab? in reply to Ian T, 09-14-2005 21:22:31
we still have a junked JD45. the cab is round on then corners like the machine. The windows are gone on right side. I think they were sliders. over all not a bad cab in its day.
Maark
09-15-2005 12:13:19
Dad has a 45 roundback that he is cutting up. It still has the cab on it. Located in central Iowa.
msb
09-14-2005 21:44:58
Don't think Deere offered a cab until 1964.They did(I think) offer a canvas cab of sorts.Kind of like a heat houser with a top on it.Might not have been from Deere per see.Only time it was worth anything was when shelling corn on a REAL cold day.Custom operator that shelled some corn for me had one on his 1963 round back 45. Full Vision offered a retro fit cab.Had to be bolted together.Phone booth like accordion door.
Mike Aylward
09-15-2005 11:06:19
 Re: JD 45 combine cab? in reply to msb, 09-14-2005 21:44:58
John Deere did indeed offer a factory cab for the Hi/Lo 45's. The front window was a two piece unit similar to the one offered on the larger combines. This window allowed good visibility as long as it was kept clean, which was an almost endless job. The lower window would catch dust like you would not believe! The newer cabs with the one piece window were much better. Hope this helps. Mike
