Importance of wheel spread uniformity? 4020
Nylon
09-14-2005 20:24:29
I saw a post relating to wheel spacing being even. How accurate does it need to be? These guys were talking about rollover problems with it grossly out of symetry. I was curious if wheel space caused any problems with bearing surfaces. Not neccessarily slightly uneven but out toward the end of the axles. I would think that this would put more lever pressure on final drive bearing surfaces....what is the poop on this thought?
Thanks,
John
Nylon
09-15-2005 19:14:30
 Re: Importance of wheel spread uniformity? 4020 in reply to Nylon, 09-14-2005 20:24:29
OK dumb question:] Can we delete this post?
John
leon
09-15-2005 19:11:53
Row crop tractors are designed and manufactured with the expectation that the rear wheels might not be set the same distance from the tractor's center line. Won't hurt a thing. Watch out for roll over though especially when the wheel that's pulled in is on the down hill side of the tractor.
RalphinWI
09-15-2005 20:21:24
 Re: Importance of wheel spread uniformity? 4020 in reply to leon, 09-15-2005 19:11:53
I would say that they were manufactured with the expectation that they would be set equidistant from the center of the tractor, but also recognizing that they might not be set as such under field conditions. Small discrepancies will not be noticed, but if the difference is appreciable, it will be miserable to handle under load. The same geometric conditions suggest the availablity of heavy duty and swinging(!) drawbars on standard tread tractors.
