435 Hydraulic belts
jdman(MO)
09-14-2005 18:49:04
Any suggestions of how to get the belts off, short of removing the radiator, and fan pulley to provide clearance? Russ
8e3k0
09-15-2005 10:08:53
 Re: 435 Hydraulic belts in reply to jdman(MO), 09-14-2005 18:49:04
Jdman,are you refering to a 435 with power steering or without> On the ones without power steering the matched belts come off quite easily without removal of the rad. The belts do or should slide inbetween the shroud, fan blades, and hood support brackets if you take your time and turn the fan as you remove the main belts. The big challenge is the late model 430's with power steering was and is almost an impossiblity to remove and install belts between the limited spaces and access. The 435 is much easier as the hood/shroud and fan area is larger which allows more access space.
jdman(MO)
09-15-2005 12:16:01
 Re: 435 Hydraulic belts in reply to 8e3k0, 09-15-2005 10:08:53
This was a 435 with out PS, but only had 1/4 inch clearance. Removed radiator, and fan assy then was easy. Good thing I removed the radiatior as there was 9 pecans in the top, and 1 at the thermostat housing. Russ
