4010 black smoke
chris r. w
09-14-2005 17:20:06
I have a j.d 4010 that i recently acquired. When i take it out in the field and it in sixth gear and put the disc all the way down it will put out a cloud of black smoke but when i idle it as slow as it goes it runs nice and clean. It Also has a light sheen of oil emiting from the head gasket not enough so u can see it come out but over a hour or two of heavy use it will be covered in oil halfway down the block on one side of the tractor and when it gets warmed up i can see bubbles in the radiator. Their is also a half dollar size stain of engine oil under the blow by tube after u let it sit over night. This tractor was rebuilt four years ago and was sold as a tractor with a good engine and has about 250 hours on new motor. is the most likely problem a bad head gasket , low compression? would apreciate any advice
MSM
09-14-2005 17:30:29
 Re: 4010 black smoke in reply to chris r. w, 09-14-2005 17:20:06
The black smoke under a hard load is normal.That is not a new epa certified,computer controlled fuel system. All you are seeing is the engine working the way it is supposed to. The head gasket leak that you see possibly could be cured by retorquing the head gasket,or worse case scenario the replacement of the head gasket. Retorque the head gasket,change the oil and filter with a good quality diesel oil and take it out and work it.
