I just did exactly what you are talking about. I just fabbed a fully hydraulic setup for my model 45 on my 60. It is very easy to do using standard hydraulic fittings. If I understand you correctly, you want to run a spool valve for the loader and also run the rockshaft? Here's how I did it, and it works... Cut into the pressure line with a ferrel style elbow. Run that line to your spool input, take the return of the spool and run it into another elbow with ferrel fitting that is attached to the return line, and viola ! You've got a workable spool, and the rockshaft still works. And, you can plug into the rockshaft fittings, and they'll still work. All you are doing is "breaking" the pressure line for the spool. I welded my two elbows together with some small plate steel, so that they are nice and strong, since the JD pressure line needs the support. If you can't find the elbows and the large ferrels, than email me, and I'll put you in touch with a friend who runs a hydraulic shop. These large ferrel style fittings will cost about $20 each. Works like a charm. Tom
