4020 fan belt
kraigWY
09-14-2005 06:56:54
How do you change the fan belt on the 1971 4020 diesel power shift. I can loosen the altanator but cant see how to slide the belt off the lower pully on the drive shaft.
donmyeil
09-14-2005 13:42:51
 Re: 4020 fan belt in reply to kraigWY, 09-14-2005 06:56:54
just take the couplers apart for the front pump drive then turn the pump so the belt will come out. I would change the plastic bushings when you do this. turn the engine and pry them off. you can put them on by hand or pry against the pump drive . remove the timing cover at the flywheel so you can bar the engine over.
Mike M
09-15-2005 06:17:43
 Re: 4020 fan belt in reply to donmyeil, 09-14-2005 13:42:51
I just had a brain lapse,thanks for reminding me that you can just turn the pump coupler and don't need to slide it ahead. I have had real good luck with a sharp stiff knife and just slit those old bushings and then pop them off.Some can be a bear to pry off when they get old.
Mike M
09-14-2005 07:31:06
You are going to have to loosen up the hyd. pump coupling and slide it forward to get the belt off. I would get a new set of the nylon bushings for that coupler while you got it off as cheap insurance they don't loosen up.
