JD 420 spark plugs (Autolite)
Case1950
09-13-2005 19:55:55
Do you guys know what the Autolite number is for the plugs? It is for a JD 420 stage 2 all fuel.
Thanks,
Case1950
Henry J
09-13-2005 20:12:56
 Re: JD 420 spark plugs (Autolite) in reply to Case1950, 09-13-2005 19:55:55
Case
I run Champs H 12 im my 420 and it loves them. Anyway, I just thought I would stir the water.
It makes the autolite fans hearts keep thumping.
CPeter
09-14-2005 06:06:55
 Re: JD 420 spark plugs (Autolite) in reply to Henry J, 09-13-2005 20:12:56
I ran Champion H12 for years but now am trying Autolite 216. May go back to the Champions. Seem to last longer.
CPeter
Deeredale
09-14-2005 06:40:07
 Re: JD 420 spark plugs (Autolite) in reply to CPeter, 09-14-2005 06:06:55
We have been using the Autolite 216 or the AC C45L. The Champion H-12 is better then the H-10. It fouls when you are threading a new one in.
CPeter
09-14-2005 17:09:24
 Re: JD 420 spark plugs (Autolite) in reply to Deeredale, 09-14-2005 06:40:07
I agree on the H10. Also, I sometimes put an extra gasket on the plug. This does really make a difference, especially on a light use tractor used in cold weather.
CPeter
Case1950
09-14-2005 19:33:17
 Re: JD 420 spark plugs (Autolite) in reply to CPeter, 09-14-2005 17:09:24
Thanks for the replies. I have been running Champions in the 420 for a while with no problems. My Case tractors hate the Champions, they don't last long and don't run as smooth as with the Autolites. I may put some more Champions in the 420 after getting everybodys replies.
Case1950
neilho
09-15-2005 06:12:10
 Re: JD 420 spark plugs (Autolite) in reply to Case1950, 09-14-2005 19:33:17
My 420W is an oilburner. Champions last a couple hours before fouling, Autolites a couple days, and NGKs have been running all summer.
CPeter
09-15-2005 09:04:46
 Re: JD 420 spark plugs (Autolite) in reply to neilho, 09-15-2005 06:12:10
What number NGK?
CPeter
