720 LP Std. rear wheel ?
JD720
09-13-2005 19:38:16
Is there any way to determine what size rear tires a 720 Lp. std. was shipped with ? I know there were less than 300 of these built so it is worth doing right.The wheels on it now are 3010 cast centers for 38" tires.Would it be safe to assume it had 18.4 X 30 rears ? I do know it was shipped to Arkansas but that all. Thank`s
Jason Fabian
09-14-2005 12:57:26
 Re: 720 LP Std. rear wheel ? in reply to JD720, 09-13-2005 19:38:16
JD720,
As Duane said there are 3 sizes that were available on the standards. The 23.1 x 26's are extremely rare on 6 and 7 series and were for use with the Rice and Cane package. If you had the R&C there should be brake and axle shields also.
16.9 or 18.4 x 30's are the most common on standards and following those are the 18.4 x 34's.
I doubt that JD kept record of what your tractor came with originally unless it was special order like the R&C package. I would get the serial # researched through the Two-Cyl club and see what the data sheet says. If it doesn't say what it left with, chances are most likely it had 30's originally.
Jason
Island A
09-14-2005 15:00:32
 Re: 720 LP Std. rear wheel ? in reply to Jason Fabian, 09-14-2005 12:57:26
The "Rice Package" was only on model D, R, 80, 820, 830.
You could get a 70/720/730 or 60/620/630 with rice tires, but no mud shields.
Dave
Duane Larson
09-13-2005 20:35:00
JD720,
A 720 Standard had several rear wheel/hub options, including:
F1590R cast center for 16.9 or 18.4-30 tires/rims
F1591R cast center for 23.1-26 tire/rim
R21480R cast center for 18.4-34 tire/rim.
I don't know if the Two Cylinder search would provide wheel info or not, but these were the options for Standard tractors. I am not aware of any difference for LP versions.
buickanddeere
09-15-2005 01:59:24
 Re: 720 LP Std. rear wheel ? in reply to Duane Larson, 09-13-2005 20:35:00
Factory 15-34/18.4x34's on a 70/720/730 standard are rare critters.
Jeff Oliver
09-13-2005 20:09:06
if i can find my data book tonight I'll see if it is in there and let you know.
