1000 RMP PTO option on 435, 730, 440, etc. how ope
Robert Cash Mol
09-12-2005 22:26:12
I might have a 435 with the factory 1000 RPM PTO option...the serial number matches with one of the 30 listed in the reference book that were supposedly the # of 435's ordered with the 1000 RPM PTO option. I'm not sure what to look for or how it works since we just got this tractor in, or maybe something is missing now? I know the 2010 models I've seen have a separate inlet above the main 540 inlet to put the spline in for the 1000 rpm. Is this how the 2 cylinders were designed cause the only info I could find on this topic were the posts copied below and some of the explanation I couldn't visualize. If anyone has a picture of a 2 cylinder set up with 1000 rpm let me know. thanks.
�In 1959 the 430,435,440,530,630 & 730 could be ordered with a 1000rpm pto. The 840 industrial units had a 1000 output starting at serial number 8400900. No more than 300 of those 840�s were ever made.� 2.�In my 730 operators manual in the specs notes the tractor may have a 540 or 1000 PTO from the factory. I never saw a two cylinder with a 1000 PTO. In another part of the book it shows an external mounted speed changer on the PTO. A gear box slid over the 540 shaft with a 1000 PTO shaft coming out directly behind the 540 shaft and I have seen these. The 4010 and 4020 are a completely different and new design. On the 4010 the front and rear PTO runs at the same speed, which ever speed it is shifted to buy changing the stub PTO on the rear shaft. A 4020 rear speed is also made to be either 540 or 1000 but the front shaft always runs at 1000 rpm regardless of which way you are using the rear.� 3.�I was just in Moline at the collector center and they had a 630 standard with just about every option including the 1000 rpm pto - it was just another gearbox behind the 540 pto. First one I have ever seen.� SO I have tried to put a picture of mine below...if this does have a 1000 prm option is it missing a part and does this slide over it? And would there be a control lever or device I could check for elsewhere on the tractor? There is a set screw on the pto shaft that seems you can remove the pto but maybe all models have this. Same with all the rear pictures I've seen of a 435 (like the 2nd one below) all show that other plate cover area right above the pto shaft, but not sure what that is? And finally someone today thought he remembered that some 2 cylinders had some sort of small sleeve storage area under them and he said maybe this was the storage area for the above mentioned "gearbox" or "external mounted speed changer" so that it could be stored for later use? Thanks for any help!
buickanddeere
09-15-2005 02:14:33
 Re: 1000 RMP PTO option on 435, 730, 440, etc. how in reply to Robert Cash Moline, 09-12-2005 22:26:12
Five minutes with a parts manual will tell you everything. 1-800-522-7448. The 840900+ still had the 540 rpm PTO. Just an external 90 degree vertical drive bolted onto the tractor's horizontal output shaft, geared to 1000rpm. Internals were the same. Either a 540 or 1000rpm PTO stub shaft slides into a 435/430/330/440. Speed is controlled by which cluster gear pair at the front of the trans are installed. Mother Deere sold retrofit internal PTO gears to convert the 520/530/620/630/720/730. Factory 1000 rpm 530/630/730's could be ordered. As JR wrote. 1000rpm is probably the most resisted factory option Deere sold on two cylinders. New Generation usually supplied a 1000rpm pto anyways. The majority of of 10,20 & 30 series 1000rpm shafts probably have the factory paint still intact.
Mike M
09-13-2005 06:55:21
Have you checked the speed of the pto shaft there now ? It could be 1000 and just have the wrong splines ? I think the 440 crawler uses the hole above where your pto is to run a winch,take that cover off and check the speed of that shaft.
Bob
09-13-2005 04:09:27
According to original 435 literature I have, the 435 could be ordered wirh one of 4 choices:
1.) Regular transmission-driven "560" RPM PTO.
2.) Continuous-running "560" RPM PTO.
3.) Continuous-running "100" RPM PTO.
OR:
4.) PTO with EXTERNAL gearbox switchable between "560" and 1000 RPM's
BOb
09-13-2005 04:11:34
 Re: 1000 RMP PTO option on 435, 730, 440, etc. how in reply to Bob, 09-13-2005 04:09:27
The "100" in line 3.) should read 1000 RPM PTO.
Coffee hasn't kicked in yet!
