5020/Roosa pumps
southernsmoker
09-12-2005 19:32:47
Are there any other larger Roosa Master pumps or pump heads that will fit on the 5020 531D engine. Does Roosa make a pump with plungers bigger than .370? Also, where can I get larger injectors? I already have the pump maxed and I need more to turn the 3LM turbo. Any info or parts are greatly appreciated.
txgrn
09-14-2005 06:53:02
 Re: 5020/Roosa pumps in reply to southernsmoker, 09-12-2005 19:32:47
Did you see the pic posted on here several months ago where a guy with a 10xx IH was pulling and blew his block half into (right down the middle of the water jackets front to rear) cause he had his turbo turned up too high.
The picture also captured the shocked look on his face as the cowling and top of the engine were flying up in his face.
They'll only take so much.
Mark
southernsmoker
09-14-2005 15:07:45
 Re: 5020/Roosa pumps in reply to txgrn, 09-14-2005 06:53:02
That sounds like a thin cast block. Anytime something is modified over factory, one can't expect the machine to run and last as it would if it were factory. I've been pulling for quite a few years and am fully aware that unexpected things happen.
720Deere
09-14-2005 17:06:11
 Re: 5020/Roosa pumps in reply to southernsmoker, 09-14-2005 15:07:45
I think over 200 psi of boost had a little something to do with it. Those blocks are hard to keep together under high boost from what I understand.
Bill5010
09-13-2005 06:15:43
I am running a very similar set up. call me at 217-822-8485 and I might be able to help ya or have something for ya to buy..Bill
