44 JD A questions
Phillip W.
09-12-2005 16:41:01
I just bought a 44 JD A. The only number on the block is a number 32 cast into it, why is there no JD number? Is a DLTX 53 the correct carb for this tractor? Where is a good place to have the carb and mag rebuilt? Where is a good place to buy parts? The seat assembly on this one is completely different than the one I had on my 44 JD B, was there more than one seat assembly available for this year? Thank you
G/MAN
09-12-2005 17:04:13
 Re: 44 JD A questions in reply to Phillip W., 09-12-2005 16:41:01
If it's a Deere block, there will be more casting numbers somewhere on it, although they may be hidden where you can't see them, such as behind the frame rail. The DLTX-53 is correct for all-fuel "A"s from serial #499000 to #583999, which is the end of production, if memory serves. If your serial-number falls in that range (I don't have the year/serial-number chart in front of me), then the carburetor is correct. Robert's Carburetor Repair is excellent. We've sent several there and they come back looking like a work of art, almost too pretty to install, and work great. He's also more than willing to answer questions, which cannot be said about another major carburetor shop based on what I've heard. There are also some others around, but I have no experience with them. If I'm not mistaken, Robert's also does magnetos, so one box and one shipping cost and destination could fix you right up. Many parts are available from your local Deere dealership. And contrary to what you may read on here at times, Deere is NOT always higher in cost. In fact, in many cases they are CHEAPER on some parts like gasket kits. Apparently a lot of aftermarket places profit off the fact that people automatically assume Deere would HAVE to be higher and therefore don't bother checking. Phone calls or visits to local dealers are cheap, and once again contrary to the belief of some, there ARE parts and service people at Deere dealerships that are interested and/or knowledgeable in and about two-cylinders, and are willing to help and answer questions if they can. I'm one of them, at least on the "interest" side. I'm far, far from an expert on the "knowledge" side. If you're looking for NOS (new old stock) used or reproduction parts, there are many outlets. Some big outfits like Dennis Polk, K&K and the like, and some smaller "mom-and-pop" type places that most people have never heard of. A subscription to Green Magazine and/or Two-Cylinder or visit to their websites will provide you with links to parts sources. And of course there are non-Deere-specific outlets such as A&I, Abilene Machine and the like that have parts for the older tractors. And there is Yesterday's Tractors, that owns and operates this very nice free discussion board we're on right now. Kudos to them, and they deserve business from those of us that use their various boards here. On the seat, it's very possible and probably even possible that your tractor has some sort of aftermarket unit on it. They were available from many places - Tractor Supply, etc. If it's not a simple channel-iron and pan, it's probably aftermarket. Or it could be a "donor seat" from another brand, God forbid. The advice given to the gentleman with the "new" "H" a few threads down is something you too should consider. Get the proper manuals for your tractor. You probably won't find much in the way of "factory" service information for your "A", because I don't believe Deere made a dedicated "A" service manual. They used "general repair" manuals that had info pertaining to several models, and manuals for other specific tractors that were very similar in construction, such as the "B" in your case. There is an I&T manual for the A/B/D/G/H/M tractors, that has pretty much all the torque-specs, specific instructions, tune-up data and so forth. The actual assembly/disassembly instructions are more like a Reader's Digest Condensed Book, but the pictures are all from Deere publications and the data is usually accurate, although it can be vague at times - i.e. "assemble in reverse order of disassembly". If you don't have it, I'd also highly recommend J.R. Hobbs "Styled Letter Series" book, especially as you have a styled "B" as well. Very good info, very accurate, good history, and enjoyable to read. It also shows serial-number/breaks as Deere established them, shows various options such as wheel equipment, where special tractors like the last "A" etc. were shipped, and lists matched working equipment that would have been used with your tractor back in the day. Good stuff.
