2520 tri to wide
Kevin Rapp
09-12-2005 12:49:11
Is it possible (if so how hard) to change a 68 2520 deisel syncro from a 2 wheel tri to a wide front. I worry about stability and am thinkiing of adding a front end loader.
Thanks
Kevin
IA Farm Boy
09-13-2005 12:43:24
 Re: 2520 tri to wide in reply to Kevin Rapp, 09-12-2005 12:49:11
I recently bought a 2510 with a "Schwartz" wide front end. It is an aftermarket which uses the hubs, wheels, and tires from the narrow I was told. Seems to work great.
matthies
09-12-2005 20:40:23
Get the wedge washers or make some from the lip of a channel iron. Bolts don't always stay tight if they are not used.
Paul in WI
09-12-2005 20:10:39
A word of caution, when you change from a narrow front to a wide front you will require different length bolts to bolt the steering arm to the steering motor. The bolts that come from the narrow front are too long; if you use them they may interfere with the seals in the steering motor and cause a leak, I learned the hard way. The bolts you need are a special length so you will have to get them through deere. Paul in WI.
720Deere
09-12-2005 17:20:14
Kevin,
The swap is much easier than finding a wide front in good condition for an affordable price. After you jack up the front of the tractor and support it, it takes about 10 to 15 minutes to remove the rollomatic and another 45 minutes to install the widefront. As I remember, there are four bolts and they are a pain to get started. A few more bolts for the steering arm and you're good to go. We used a skidsteer with forks. It makes the job much easier than trying to hold it up any other way.
John in Md.
09-12-2005 17:00:22
You may want to check the serial number tag and see what you have. I think the first year for 2520's was 1969. It's not a bad job only touchy part is lining up the holes. It's alot easier with a loader with a set of forks.
As for better stability, we worked the same ground 50 years ago with narrow fronts that you work now with widefront ends. But when you put on a loader that changes everything. If you're careful and don't overload the bucket you can get by with a narrow front, if not go for the widefront.
MSM
09-12-2005 13:05:22
It is a bolt on. Get a Deere wide front (2510-4320 all fit) from a salvage yard with all the bolts,wedge washers.It takes about 2 hours to swap with hand tools.
bernie in VA
09-12-2005 12:58:48
We bought a 2510 narrow front new with loader years ago. It works fine and has been used to load logs, large hay bales etc. One just has to be careful. We recently installed a ROPS and should have done it a long time ago.
