Conversion of 5 btm F145H plow to 3 bottom?? Ever
tyler-mo
09-12-2005 11:52:14
I've got a F145H 5x16" bottom plow (semi-integral) that I'd like to convert to a 3x16" bottom plow. I was wondering if anyone has done this or would be able to provide me with any pictures of the 3 bottom version of this model so that I'd have at least an idea of what I'd need.
Thanks for any help,
Tyler in Missouri
Dale in IN
09-13-2005 06:12:53
 Re: Conversion of 5 btm F145H plow to 3 bottom?? E in reply to tyler-mo, 09-12-2005 11:52:14
Just did that to an IH 550. Haven't had it hooked up yet. It has set for about 15 years and my pivot post is still frose up. Have got the back steering post free though. And everything on the back moved forward. As soon as I get some beans cut I am going to try it out.
There was a 3 bottom semi mount at the Portland IN. show. I do not know wheather it had been chopped or if it was an orginal. But it was all painted up and looked good. I Think it was hooked behind a 2010.
G/MAN - update...
09-12-2005 16:06:32
I pulled the Operator's Manual up on Service-Advisor. It doesn't appear that Mother Deere intended a five-bottom plow to have two bottoms taken off, which is no surprise - who would buy a 5-bottom to get 3? They show dropping one bottom off the 4-bottom to make a 3-bottom, one bottom off the 5-bottom to make a 4-bottom, and one bottom off the 6-bottom to make a 5-bottom, all in the "reducing plow size" section, but that's it. Before removing, sliding and "chopping", I'd suggest advertising on here and elsewhere to find a plow of the size you want, instead of chopping up a good plow. I'm sure there is someone out there with what you need, and someone else that wants what you have.
G/MAN
09-12-2005 16:00:37
I'll check the F145H Operator's Manual and see if it mentions dropping bottoms. I know the 810-series integral plow manual does.
Scotmac
09-12-2005 14:29:53
We used to drop one bottom off...not a big deal. Just unbolt the back two bottoms, and then slide everything forward. You will have whats left of the main beam and the steering rod sticking out behind you, but if you want to leave it a three bottom for the rest of the time you own it, just torch the left over pieces off.
