1949 JD-B Synthetic Oil
courtland ridin
09-12-2005 10:08:41
Is is generally ok to use synthetic oil in the old tractors?
buickanddeere
09-16-2005 01:20:07
 Re: 1949 JD-B Synthetic Oil in reply to courtland ridings, 09-12-2005 10:08:41
If the tractor is used in extreme heat, extreme cold or has been highly modified for more power. Then yes.
lencollings
09-14-2005 07:29:21
If you have an old tractor that has been ren several hours with non detergent oils the detergents in the synthetics may wash all the built up carbon out from behind the rings, This may cause the rings to exert less force on the cylinder walls as they no longer have carbon deposits holding them out. If you have just put the tractor back together after overhauling the Synthetics are too slick and will not allow the proper break in to happen. thus you will have to do a tear down and re hone the cylinder walls. New John Deere diesels come from the factoty with a special 10W 30W break in oil. Once broken in than synthetics may be used. If you use a syntetic you will need to change the filter out if you intend to go an extended time between changes. You may be better off using regular oils.
DickD
09-13-2005 12:29:24
Putting that synthetic oil in an old 2 lunger would be like putting white sidewall tires on a manure spreader. The rod and main clearances in these old 2 cylinders were such that the 30 weight worked well in them. It was'nt unusual to hear about them going 8 or 10 years without teardown. Save your money!
G/MAN
09-12-2005 18:08:34
I tend to think it would be a waste of money, and I certainly wouldn't use it in a fresh overhaul, as you would have a terrible time getting it to break in, if you could do so at all. If this makes any sense, today's convential oils are so far and away better than what was available when that "B" was new that they may as well BE synthetic oils in comparison. To say it another way, today's oils are ten times better than those old oils than synthetics are better than today's conventionals. Use modern oil of the proper viscosity and don't lose any sleep worying about super oils.
courtland RIDINGS
09-13-2005 10:48:08
 Re: 1949 JD-B Synthetic Oil in reply to G/MAN, 09-12-2005 18:08:34
THANKS
WSW
09-13-2005 21:00:52
 Re: 1949 JD-B Synthetic Oil in reply to courtland RIDINGS, 09-13-2005 10:48:08
I bought a 1939 Model B and was told that non-detergent oil might be better than detergent oil but not to mix them. Recommendation was to use 20 or 30 wt. As this is my first tractor I want to start off right. What do you think?
G/MAN
09-14-2005 07:40:11
 Re: 1949 JD-B Synthetic Oil in reply to WSW, 09-13-2005 21:00:52
Putting detergent oil in an old tractor with a "dirty" engine will result in the new oil breaking up all the old deposits over time, and the oil will tend to get "dirty" fairly quickly.
CLW
09-12-2005 11:49:44
Those in the know seem to say it may cause leaks in places regular oil don't.
CLW
old
09-12-2005 11:41:31
I wouldn't unless it was a freash rebuild on the engine.
