1949 Model A
Larry 2809 C
09-11-2005 18:46:47
My John Deere A is dripping oil when the engine is running. (not Fast, but a drip every 15 seconds or so) It is seems to be coming from the underside of the engine where the block connects to the tractor. Could a seal have gone bad or what? I have corrected some carb problems and some gas may have diluted the oil a little, but i wouldnt think that would have caused the problem. thanks for any help.
DW
09-12-2005 09:08:22
 Re: 1949 Model A in reply to Larry 2809 C, 09-11-2005 18:46:47
I have a late styled A that leaks there too. Only maybe not quite as bad. There is a gasket between the block and the main case, and I am thinking this could be the culprit. I haven"t gotten serious about tearing this tractor down yet but I am confident that a new gasket will cure this ailment.
