B DLTX 67 Throttle arm Screw adjustment procedure
Len Collings
09-11-2005 18:43:47
Where is the starting adjustment point for the idle Throttle stop screw on top of the DLTX 67 carb. What is the procedute to adjust this screw correctly & get it functioning correctly.
Skyhawk Greg
09-12-2005 08:36:24
 Re: B DLTX 67 Throttle arm Screw adjustment proce in reply to Len Collings, 09-11-2005 18:43:47
Since you are asking about a DLTX 67, I will assume it is a late styled B. Going from memory, the fast idle is about 1100 rpm and the low idle is supposed to be about 400 (?) rpm. Nobody does this though, as they like to hear engines run as slowly as possible. You can adjust it to run as slowly as you like, but keep in mind that the impulse coupling will engage somewhere around 250 rpm. If this isn't what you are asking about, and you want to know about the load and idle screw adjustment needles, go to Robert's Carburetor web site, and he has a very good explanation.
WSW
09-13-2005 21:06:45
 Re: B DLTX 67 Throttle arm Screw adjustment proce in reply to Skyhawk Greg, 09-12-2005 08:36:24
What is the address for Roberts Carburetor website? I need instruction on the carb for a 1939 Model B. By the way, is the designation (such as DLTX67) found on the carb?
Skyhawk Greg
09-14-2005 06:28:10
 Re: B DLTX 67 Throttle arm Screw adjustment proce in reply to WSW, 09-13-2005 21:06:45
www.robertscarbrepair.com
The letters DLTX will be raised, and part of the casting near where the venturi is located, and the 67 will be stamped on the flat surface just next to it.
