50 Series Engine???????
Wide Open
09-11-2005 18:32:00
Hi guys. I have a quick question for ya. First of all I am not a Deere man, so cut me a little slack if this is a dumb question, but I have been looking for a 8630 or 8640, and I see some advertised saying "50 Series Engine" what does this mean? Did the 8650 not use the same engine as the 30 and 40? Is the 50 series a good engine? Anything I should watch for or check for when buying one of these tractors? Thanks for any help. -Wide Open
Skip 33652
09-12-2005 19:20:44
 Re: 50 Series Engine??????? in reply to Wide Open, 09-11-2005 18:32:00
deere had a problem with the early engines and knew it.The 4 wheel drive tractors tend to acummulate massive numbers of hours pulling heavy tillage tools day after day and camshaft wear was unaceptable. I know of acouple of these that have nearly 30,000 hours and still earn there keep. they had a program where they put a new 50 series engine for not very much $. far less than an engine overhaul especially if one needed crank and or block after losing oil pressure.I believe the program started about 1980,so technically most of these 50 series engines were actually 40 series engines, as the 40 series tractors were built with both new and old style engines 50 series means newer style.I knew of only one 8630 that was not updated and I think it went salvage some years back. I think an 8630 with an original engine would be a rare bird not valuable just very unusal.Paul
Bob
09-12-2005 21:06:07
 Re: 50 Series Engine??????? in reply to Skip 33652, 09-12-2005 19:20:44
I have an 8630 with about 9000 hours on the original engine!
I wish it WAS valuable!
Bob
09-11-2005 22:00:27
The "30", "40", and "50" all used the 619 cubic inch engine.
Many changes (improvements?) were made as time went by.
On problem was the gears on the camshaft and oil pump wearing out. The oil pump would then stop, and almost instant engine destruction would occur.
They eventually changed the system, so the oil pump hung under the timing gear train, and was driven off of the crankshaft's timing gear.
I BELIEVE that change was made for the "50" Series.
G/MAN
09-12-2005 16:41:33
 Re: 50 Series Engine??????? in reply to Bob, 09-11-2005 22:00:27
I haven't been around many 4wds, but row-crops pretty much used the same set-up up to the 40-series with the 400-series engines (404 and 466), and yes, cam-gear/oil-pump-gear wear and failure can be an issue. I think the change was actually made during 40-series production, as they show the "early design" with the cam-driven pump and the "late design" with the crank-driven pump in the 40-series parts catalogs. It's my understanding that most of the failures happened to tractors that were started frequently with cold oil, which put a lot more load on the gears and caused them to wear more quickly. There's not a lot of material there to begin with, and it would stand to reason that a bigger pump, such as in a 619, would put even more load on the gear teeth. I've checked several 404 and 466 engines in "field only" row-crop tractors with up to and in excess of 10,000 hours on the original cams, and they were fine because the tractors didn't get cold-started in the dead of winter much. There's a Deere special tool for actually checking the amount of wear at the gearset, based on backlash.
Bob
09-11-2005 22:01:40
"On problem..." should read "ONE problem..."
