720 money pit
Elmer Jesok
09-11-2005 15:46:48
I bought this 720 3 yrs ago,from the son of the original owner. It ran good looked good, I did notice a noise in fifth , I was told it was just the brg on the rite side cover, WRONG after replacing all the transmission brgs rebuilding the top shaft, After changing the engie oil, and pulling the tractor in the field, I was getting oil mist out of the exhaust when idling. I tried all the minor simple things, Finally after a year of horseing around ,I bit the bullet and tore it down, I never saw a engine so worn out and still run like it did , SO now in all my whining, buyers of diesels be careful. discussed
Dirtjockey
09-12-2005 09:11:45
 Re: 720 money pit in reply to Elmer Jesok, 09-11-2005 15:46:48
I would agree that most old tractor can become a money pit. I went out and bought the best 720D that I could find, but still has $3000.00 in parts in it. Still needs rear tires and rims. The small things add up fast on all tractors. $20.00 dollars bushings AND $18.00 GASKETS by the bag full.
Mike M
09-11-2005 18:26:42
Your not alone,I also have a 720 D money pit. You sure are right about them being able to run with many problems.
720Deere
09-11-2005 16:24:56
You may as well assume that any 2 cylinder diesel that doesn't perform flawlessly, (ie no oil smoke, good powersteering, quiet transmission, good pony) etc., will be a money pit. They are expensive to work on and were usually worked to death in there day. The diesels were usually the "big tractor" on the farm and were worked hard. It's hard to find one in good condition unless it has already been restored.
WeirdDeere
09-11-2005 18:06:59
 Re: 720 money pit in reply to 720Deere, 09-11-2005 16:24:56
I'll definitely agree with ya! I've dumped way too much money in this 80 of mine. Pony, powersteering valve, PTO, fuel gauge, repop lights, etc. It was worked, and worked hard. The pony and powersteering were updated to later types, AND the PTO was also apart BEFORE I got there.
I still have to fix the transmission, Powr-Trol pump, and possibly the powersteering pump. I don't even want to LOOK at the diesel. It still puts out stock Horses-I'll leave it alone!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
F-I-T
09-11-2005 18:42:02
 Re: 720 money pit in reply to WeirdDeere, 09-11-2005 18:06:59
I guess I look at it a little differently.....
I mean on a tractor over 45 years old, probably not the original hours showing, why wouldn't you just assume that it is worn out.
With the exception that the loose flywheel/worn crankshaft splines tend to be more prevalent, but not restricted to, diesels, and the overhaul of the diesel injection and tranfer systems (which cost about the same or less to rehab as a carb trip to Robert's), pistons, mains, boring and crank work cost about the same.
The odds of finding a truly cherry 1958 anything is becoming more and more remote, and that was the same in 1965. There are are darn few 1958 cars or trucks that you would be willing to load down and drive at their rated capacities unless they had undergone a tone of rework.
Just buy'em figuring that you have to rehab everything, and if you don't, then you'll be pleasantly surprised.
As always, my two cents, and probably not worth half that.
Frank
PS:
Brandon! Glad to see you got out of that scrap for lighting up in the library! We were all pretty worried. :)
ebbsspeed
09-12-2005 09:24:51
 Re: 720 money pit in reply to F-I-T, 09-11-2005 18:42:02
Lighting up in the library? I missed something.
F-I-T
09-12-2005 12:08:55
 Re: 720 money pit in reply to ebbsspeed, 09-12-2005 09:24:51
It's a long and painful tale from johnnypopper.com.
