24v to 12v conversion on JD3010
utilityguy1
09-10-2005 18:52:27
I have been considering putting my 3010 on a 12v charging system and only using 24v for starting. I figured on putting a two way, 3 position switch in. One direction for charging, the other for starting. The batteries can be charged in parallel and by flipping the switch, the alternator can be isolated so the batteries can be used in series when the solenoid is engaged. The switch idea is to kind of foolproof the thing so I don"t try and start it why the alternator is turned on. The center position on the switch is dead so hopefully this will prevent unintended drain on the batteries. Anyone try this yet? Any expected problems?
ET
09-12-2005 05:39:27
 Re: 24v to 12v conversion on JD3010 in reply to utilityguy1, 09-10-2005 18:52:27
I prefer the 24v system. If you understand it and fix it right it beats a 12v conversion any day, especialy if you tractor has any internal hydralic leaks like most of them do after 40 years. The circut breaker kit and cable and fuse wire kit between the batteries does a good job of eliminating burned wiring or the old start by itself trick. If one battery is draining clean the brush dust out of the starter and replace the brushes if they need it. I find that everbody does a back yard conversion a little different and they can be a real nightmare when things need more work later on.
Tx Jim
09-11-2005 03:47:11
 Re: 12v conversion on JD3010 in reply to utilityguy1, 09-10-2005 18:52:27
Why not just change your 3010 to 12V and be done? Tx Jim
Bob
09-11-2005 10:03:45
 Re: 12v conversion on JD3010 in reply to Tx Jim, 09-11-2005 03:47:11
Why not just leave it 24-Volt and make any needed repairs to get the system "up to par"?
I had always planned to change my 24-Volt 4020 over to 12-Volts, because I, too, thought the original 24-Volt split system was not worth repairing and keeping.
Quite a number of years ago, I was having some electrical problems, and didn't have time to lay it up to make the change to 12-Volts, so I made the needed repairs to the 24-Volt system, and it has worked well ever since.
After working on several 5010's, 4010's, and 3010's that were having starting troubles after 12-Volt conversions, I've decided to simply leave mine 24-Volt, and make any needed repairs as they come up. The 12-Volt systems are not without problems, either.
There is no reason to do the series-parallel thing, either, to use a 12-Volt alternator, as isolated ground 24-Volt alternators are readily available. Why add another relay, and add a number of high-current connections to the possible list of "failure modes"? The original Deere-Delco split 24-Volt system really is not that bad, if you take the time to learn how it works, and keep it maintained.
Tx Jim
09-12-2005 04:15:01
 Re: 12v conversion on JD3010 in reply to Bob, 09-11-2005 10:03:45
Bob.I hope you install circuit breakers to help 24V from shorting out and catching on fire. While I worked for JD dealer 24V were alot more prone to draining batteries and burning than 12V systems. Each to their own! I'll take 12V myself. Tx Jim
buickanddeere
09-10-2005 21:12:11
Why not use an off the shelf relay instead of "re-inventing the wheel". More fool proof than a manual switch too.
utilityguy1
09-11-2005 06:29:10
 Re: 24v to 12v conversion on JD3010 in reply to buickanddeere, 09-10-2005 21:12:11
buickanddeere...the relay idea sounds good. How would you suggest I install? Normally closed until the key is turned? Or have I missed a more obvious solution? I do have a way of complicated things....
buickanddeere
09-11-2005 08:40:57
 Re: 24v to 12v conversion on JD3010 in reply to utilityguy1, 09-11-2005 06:29:10
Highway tractors use a 12V/24V electrical system with the starting relay you need.
