1958 model 620
Larry 2809 C
09-10-2005 18:10:14
What would be your thoughts on valuation of a model 620 that i found. The tractor has been setting for a year, lots of surface rust,all tires need replaced,seat and battery box rusted away,muffler,exhaust pipe gone, manifold has a hole and needs replaced. Tractor has power steering, but dont know if it works, and the top link for the 3 pt is missing. Dont know anything about the engine at this point. Metal is fairly straight..Thanks for you help.
JD runner
09-14-2005 15:27:29
 Re: 1958 model 620 in reply to Larry 2809 C, 09-10-2005 18:10:14
I'd say it depends on the actual condition of the engine and transmission, if good I'd say about $1500-2000. If bad I wouldn't pay more than $750. Just my opinion, good luck. -JD
CLW
09-11-2005 21:53:43
Larry, I wouldn't pay more than $750 max. You don't know what else will be wrong with it. Was it left outside with no cover on the exhaust? There are running 620s out there for $2500.
CLW
720Deere
09-11-2005 04:40:30
It sounds like you are looking at a $2000 tractor. It is likely worth that much in parts, but it will probably take closer to $3000 more to make her right again.
