Canadian JD 2120
Ernest Owens
09-10-2005 10:42:01
I have been looking at a JD 2120. It is clean,4500 hours,starts & runs good,has a JD 48 loader,also has parts book,operator manual and the owner manual. But the weight of this tractor or the loader is not listed in any of the manuals. Does anyone know the weights or have a Canadian website where I could find out this info? Our local JD dealer calls it a gray market tractor because it was not intended for U.S. import. But it is still a John Deere.
Matt in PA
09-12-2005 17:40:40
 Re: Canadian JD 2120 in reply to Ernest Owens, 09-10-2005 10:42:01
Ernest, I have a 2020 gas with a 48 loader. The manual states the loader weigh 1220lbs with 60 inch material bucket. My tractor and loader combo on the scales is about 7400lbs. Hope this helps. Matt
buickanddeere
09-11-2005 19:59:48
Parts are no problem. If you have the part number and it's stocked somewhere in the world. The part will be on you Dealer's counter pronto.
mitchp
09-11-2005 09:40:14
hey ernest, i have a 2120 and it is a great tractor, motors are very strong and i've had hardly any problems out of mine at all. i would guess the tractor probably weighs about 6000 pounds, loader may add another 1000 to it. as far as buying it, i would buy another one in a heartbeat, mine has worked hard and proven itself time and time again
Ernest Owens
09-20-2005 10:31:15
 Re: Canadian JD 2120 in reply to mitchp, 09-11-2005 09:40:14
mitchp I don't know your location. But the tractor is located in Clark County Washington,just across the Columbia River from Portland, Oregon. The tractor is to big for my needs. It also doesn't have a true three point hitch with draft control. The 3pt has two hydralic cylinders on the lift arms that are controlled by one of the spool valves. To use the loader,one spool valve operates the up/dwn,the other valve,the bucket tip. To use the 3pt the bucket hoses are disconnected and the 3pt hoses connected. 50% of my work is frt loader/aft box. Right now I don't have time to rework this tractor for my needs. E.
