Bad oil leak from hole in rear end casting????
jonesy
09-10-2005 08:09:13
Im working on a 41 B and there is a real bad rear end oil leak coming from what looks like a 1/4" hole in underside of the casting near a drain plug. Anyone know what seal is out and how hard is the fix. Thanks
DUP
09-10-2005 16:28:50
 Re: Bad oil leak from hole in rear end casting???? in reply to jonesy, 09-10-2005 08:09:13
Had the same thing on a 43 A I just put a 1/4 pipe plug in it never had a problem with it
Mike M
09-10-2005 11:57:06
I wonder if you have a bad casting that has a sand hole ? or something ? You may have to tap it and put a plug in it too.
