430 clutch
steve Ga
09-10-2005 04:59:00
I am looking at a 430 owner says is a 2 stage clutch(with PTO clutch stuck)any way to verify this without pulling tractor apart?anything different about torque tube,trans. housing serial number etc. Thanks,Steve
buickanddeere
09-10-2005 06:43:00
 Re: 430 clutch in reply to steve Ga, 09-10-2005 04:59:00
Pto drives 100% of the time? Count on anything from a total clutch job to a bent, creased, transmission input tube/shaft, pilot bearing etc. The vender's price will have to allow for such. Then again you maybe lucky and it's just a little rust on the pressure plate or flywheel. That spicer clutch and parts can be found cheap in old Massey model 35's etc.
steve Ga
09-10-2005 05:19:07
I want to add: it is a 5 speed,ser # 147862 also on trans housing(left side)is casting # M4258T
Wayne in Tn.
09-10-2005 10:25:18
 Re: 430 clutch in reply to steve Ga, 09-10-2005 05:19:07
If your wanting to verify if its a 2-stage, heres how: On a 2-stage, sitting on the tractor, move the PTO shifter to the right and PTO is in gear, move it to the left for out of gear. A non-2 stage will work backwards from this.
Another tip, those 2 stage Dubuques can be a pain and costly to repair. I had much rather have a non- 2 stage, they give much less trouble and you can always use an attachment on the PTO shaft, called an override clutch. They cost about 30 bucks at any farm supply store.
