Alternator conversion
Tom K
09-09-2005 14:03:09
I want to convert my 70 gas with 12 volt positive ground to an alternator. Any advice?
jason r
09-12-2005 07:12:59
 Re: Alternator conversion in reply to Tom K, 09-09-2005 14:03:09
why?
Tomk
09-13-2005 09:07:05
 Re: Alternator conversion in reply to jason r, 09-12-2005 07:12:59
I know, I know. Everybody wants to keep the old girls as original as possible. But I like to use this tractor for light utility work and consequently she often gets started, run for ten to twenty minutes and then may sit for a week. I find that the battery, which is a year old Deere Strongbox, requires recharging about monthly.
That's why.
Glen in TX
09-09-2005 21:39:53
Here is a couple sites with some wiring help and advice. www.alternatorparts.com and www.madelectrical.com/index.shtml
buickanddeere
09-09-2005 14:44:13
How familar are you with electrity and figuring out circuits? Those $39.95 alternators at Napa keep these discussion groups going with frustrated people looking at a nest of generator wires. What serialnumber and model of Delco is one there. The later Delco's have plenty of zip to keep the battery charged.
old
09-09-2005 14:18:24
Well you would have to switch the ground to - and you would also need to change it on the coil if it has one that is. I'd put a delco alternator on it not hard to wire up.
960
09-09-2005 17:56:17
 Re: Alternator conversion in reply to old, 09-09-2005 14:18:24
You need a Delco single wire self exciting alt. and also remember to reverse wires on ammeter in addition to the coil and battery.
RayP(MI)
09-10-2005 18:23:50
 Re: Alternator conversion in reply to 960, 09-09-2005 17:56:17
And be sure to change to a 12v coil or add a ballast resistor to the coil circuit. Also don't forget to change all light bulbs to 12v.
buickanddeere
09-10-2005 21:18:29
 Re: Alternator conversion in reply to RayP(MI), 09-10-2005 18:23:50
??? A spark ignition 70 was 12V from the factory.
