HELP! Taking Clutch Apart.....
Shawn Slyter
09-09-2005 04:44:22
Okay guys I need your help. I am in the process of replacing the clutch disks in my 46 A. Well, I got the adjustment plate and the outside disk, but I can't get the main drive disk to move. Looking in my manuals again last night I see that there is a small pin/rivet holding it on. How do I remove this pin and the main drive disk??
Maark
09-09-2005 11:46:56
 Re: HELP! Taking Clutch Apart..... in reply to Shawn Slyter, 09-09-2005 04:44:22
Whatever you do, don't put the puller on the outside of the clutch driver. You will break it.
MITCHP
09-09-2005 08:45:23
I HAVE A QUESTION REGARDING THE CLUTCH PULLEY, IF I TAKE OUT THE CENTER BOLT OUT OF THE END OF THE CRANKSHAFT, CAN I THEN SEE IF MY 2 V MARKS ARE LINED UP OK? MY TRACTOR (46a)HAS SOME VIBRATION WHEN AT FULL THROTTLE, SHAKES PRETTY BAD
Mike M
09-09-2005 09:37:06
 Re: HELP! Taking Clutch Apart..... in reply to MITCHP, 09-09-2005 08:45:23
That model may not have V marks and use the notch and rivet. For sure take out that bolt and washer and see what you can find. Check your flywheel for V marks being in alignment too.It is possible to have a driver with a V and a crank with a notched spline,try lining these up if they are not. I think it has been said here before that if you have no marks make sure the heavy side of the clutch driver and flywheel point in opposite directions.
jason r
09-09-2005 07:51:31
here is an idea i used....if your drive disk has two threaded holes in the disk and the large bolt in the center going into the crank save your money on a puller. get two 3" grade 5 bolts that will screw into the two holes in the drive disk. remove the non swing part of your drawbar (the one with all the holes hopefully it isn't the welded kind) and put the two bolts through the holes on the drawbar. snug the bolts down good and even then with another wrench start to turn the center bolt out of the crankshaft. the pressure of the center bolt turning out on the drawbar will pop the drive disk off the crank evenly. the drawbar is thick enough that i won't bend. i had to do this on a late a and b and didn't have the money to spend on a puller. hopefully i explained this ok.....
Mike M
09-09-2005 06:06:45
That rivet is just there to match up with a spline that is notched out so you don't put it on out of balance. You need to loosen the bolt in the center holding it onto the crankshaft.If your lucky enough to have one of the few left that the splines aren't shot you are going to need a puller to pull it off.That model some square nuts may slip in behind the notches in the disk and you may be able to screw some bolts in to push it off.
Shawn Slyter
09-09-2005 06:17:37
 Re: HELP! Taking Clutch Apart..... in reply to Mike M, 09-09-2005 06:06:45
Okay, so the key here is the SQUARE headed bolt..I tried the bolt thing with a hex head and it didn't work. Then last night I had a cheap puller and it broke without the main disk even moving!! Looks like I will have to step up and buy a good puller or I will try the bolt thing again.
So to review...the rivet is just there as a guide and doesn't actually hold the disk to the shaft.
F-I-T
09-09-2005 08:05:00
 Re: HELP! Taking Clutch Apart..... in reply to Shawn Slyter, 09-09-2005 06:17:37
Shawn:
Go find yourself the proper square nuts at Fastenall or some good fastener dealer and the proper bolts and keep them for whenever you'll have to pull the driver. They work like a charm. I keep a pair in my specialty tool box for just that task.
You can fabricate them out of some bar stock, but square nuts are still available out there, you just have to be persistent, and they are much cheaper than a a puller that can break that expensive cast piece or itself.
Frank
Mike M
09-09-2005 06:26:02
Sounds like your getting it. I use a good puller and just hook the legs in the slots where you could put bolts. Tighten it up real good and if it still doesn't move give the end of the puller a good hard whack that should shock it and make it pop off.
