630 gearing
C.R.B.
09-09-2005 04:02:22
Hello I have a 630 rowcrop I was wondering what would be involved in speeding the gear ratios up. I was wondering what you have to change in the trans. or diff.to gear the tractor up. has anyone taken parts from a standerd tractor and put them in a row crop. also how much does it speed it up. Thanks in advance for help.
Drew
09-09-2005 21:01:46
 Re: 630 gearing in reply to C.R.B., 09-09-2005 04:02:22
I know guys have taken the reduction gears from a 630 to slow early A's down. So you should be able to take early A reduction gears and speed a 630 up. Its about 2 teeth difference if I remember right.
Fredwi
09-09-2005 12:59:30
I think there is special gears you can put in the
tranny to speed it up. I have the special fifth
speed gear in my 730 so it speeds it up to about
8 M P H. It does not make it faster in sixth. Just the lower gears are alittle faster because I believe you take out the orignal first. Fredwi
C.R.B.
09-09-2005 12:38:13
Thanks for the reply guys. I thought that the gearing in the trans might have been different on the standerds due to the size difference in tires.
720Deere
09-09-2005 10:25:42
There was/is no difference in gearing between a standard and a rowcrop. To my knowledge, there is nothing that can be done to speed one up other than increase the engine rpm.
mike brown
09-09-2005 12:09:10
 Re: 630 gearing in reply to 720Deere, 09-09-2005 10:25:42
Larger diameter rear wheels would speed it up . 720/
730's were available with an optional low speed transmission. I don't know if 630's could be set up that way. If yours is, the shift pattern would be R124--356 instead of R123--456.
720Deere
09-09-2005 12:57:01
 Re: 630 gearing in reply to mike brown, 09-09-2005 12:09:10
The 720/730 optional gears were not creeper, they were higher speeds than standard. As far as tire size differences between the std & rc, if you look at the tires that originally came on both models, the height was actually close to the same.
My 720 has the slow gears and I have 16.9-38 tires. I changed up to them from 15.5 which are fairly short in comparison and it did not make a major difference in the ground speed of each gear. The max difference is going to be about 8% or a difference of 1.5 mph to 1.62 in low gear. Sixth gear would go from 12 to 12.96 mph. It's not a huge diffence considering eache gear jumps about 1 mph and you would only increase speeds across the board by less than 0.35 mph on average. 16.9 tires will also require more power than a stock 630 has to offer. You would gain maybe as much as .5 mph in a higher field gear, but would end up giving up 1 mph to drop a gear to compensate for the power loss giving you a net loss of .5 mph!
