4020 light problem
mark f
09-08-2005 19:02:14
On a late 4020 side console with a factory cab, I'm having trouble with the lights. Every single lamp is new, and i've checked every inch of the cab harness and replaced the wiring going to each lamp. In the first position of the switch, nothing lights up. In the second position, the flashers come on solid. In the third position, the four flood lamps around the top of the cab light up. First queston, what should actually happen in each position? Why doesn't anything work in the first position? Why don't my flashers flash? Why don't my red tail lights work? Could a bad dimmer switch cause the two front lower lights not to work?
msb
09-08-2005 20:06:54
 Re: 4020 light problem in reply to mark f, 09-08-2005 19:02:14
Just a guess,but I would say it is a ground problem.Remove one of the clamps on the Rollgard and clean the clamp and the axle up real good.
