50 b rebuilt carb still not idleing right
scott ind.
09-08-2005 18:41:30
first off thanks for all the help on my last post
i was ready to ship it off and spend the kids lunch money. the carb was real dirty and rusty
inside i cleaned ever passage using long drills
and then spaying cleaner to make sure they were clean not much looked wore out. so new gaskets and back in business I got good power
but i can't get it to idle without a little choke
i adjusted the idle needle like the operaters manual says to. this tractor has a power block it says 5"-2 whats is that all about and is this some thing john deere did or is this aftermaket?
well thanks again sorry long winded any ideals i'll try
Mike M
09-09-2005 06:21:57
 Re: 50 b rebuilt carb still not idleing right in reply to scott ind., 09-08-2005 18:41:30
The book just gives settings to start at. Open that idle adjustment up some more you should be able to make it puff black smoke then close it off it should die set somewhere inbetween.
Mike Karney
09-09-2005 04:48:32
When you rebuilt the carb, did you change the throttle shaft and bushing? It sounds like your B is getting too much air. I have a 39'B with the same problem, and I know it's getting too much air, as I had to drill a hole in the manifold side flange to get to two of the passages, (it had been cracked and welded by someone else) My tractor runs great at higher RPM's and under a load, but it won't idle worth a dime unless I choke it slightly. I would say that might well be your problem.
