420 c steering clutch adjustment
tractornutjd
09-08-2005 18:27:28
Hello, could someone tell me how to adjust the steering clutches an a 420 jd crawler?. Thanks in advance.
Bernie in MA
09-09-2005 17:24:45
 Re: 420 c steering clutch adjustment in reply to tractornutjd, 09-08-2005 18:27:28
Do you need throwout clearance? About 1/16" I think. How to get to them? Take the top square cover off and the barrel-bung cover off the front side of the housing. You'll see the TO bearing on a collar that slides in or out held by a bolt thru a slot. Loosen the bolt (9/16 socket) and pull the lever back just a little to get more clearance. If you're lucky it won't be rusted tight. The clutch has to start disengaging before the brake band tightens. HTH
JDAOS
09-09-2005 11:55:49
Try the Crawler and Dozer board archives, I think you will find all the info you need.
