B has bad knock
Harold G
09-07-2005 22:06:40
Gents,Got my 48 B started after it had about a 25 year rest[purchased it at an auction back in April] It had one stuck piston and all the valves. Gruond the valves and installed new rings, cleaned the carb and starter, crank and rods checked out perfect. Some gas and a new battery , puled the choke and hit the starter, she took off imediatly but has a problem. It has a bad knock that seems to come from the belt pully[clutch] It has no crankshaft end play but belt pully has about 1/4 inch side to side movement when clutch is disingaged. Knock changes tune when you move clutch lever in and out. It is quieter when engaged but does not dissapear. Have any of you had the same problem and how did you remedy it? Thanks in advance. Harold
Harold G
09-08-2005 20:22:59
 Re: B has bad knock in reply to Harold G, 09-07-2005 22:06:40
Thanks guys for your help. I checked the clutch drive gear and thhere is no play but I forgot to mention that the knock only seems evident on the power stroke if that is a clue. thanks again. Harold
DP
09-09-2005 04:50:12
 Re: B has bad knock in reply to Harold G, 09-08-2005 20:22:59
I'm only guessing here, but you probably checked the rod bearing clearance? How about the wristpins? As mentioned in another post here, check that the flywheel isn't loose also. That noise will carry through the tractor making it sound like its in another place.
ET
09-08-2005 11:50:24
A loose flywheel will also make a knock that transmits through the crankshaft and sounds like its in the clutch. Let us know what you find.
Terry Hahn
09-08-2005 08:22:03
Check your clutch drive. engage the clutch with the tractor not running. The pulley assembly should have very little play. If it does you might have a worn clutch drive.
DP
09-08-2005 04:41:10
Check your clutch drive to see if it is loose on the crankshaft. Also, did you check the main bearings? My first guess would be the clutch drive though. Good Luck Don
John Cunningham
09-08-2005 19:22:44
 Re: B has bad knock in reply to DP, 09-08-2005 04:41:10
Boy you folks are good. I posted about crankshaft parts for a 46 D. I too have a wandering knock that sounds like it is in the clutch area. The clutch works but you can see it dance around while running. Also my flywheel worked loose and is now out of adjustment. The flywheel is stuck out at the end now. I also pried up on the flywheel perpendicular to the main bearings and felt 10 to 20 thousands of slop or play. I know should not feel any at 0.003" If this was an Allis, ford or Ferguson I would be planning on a new or reconditioned crank and all bearings and seals. I see no after market new parts for this D. What am I getting into here.
