Impulse on Mag
jd b help
09-07-2005 19:48:40
Ok guys, can the impulse go "bad" or be adjusted on a mag? It is a Wico C magneto. If I pull the plugs out and roll the engine over, it fires right at or about TDC. But If I try to pull start it (road gear, about 4-5mph it will pop and spit and try to fire way early. Or is that just too fast for the impule to work? I don't have another tractor around to pull it, have to use the truck. Once it is running it runs great. But it's a bear to start. The starter bendix keeps kicking out, so I am stuck pull starting it for now until I can get that fixed. Compression is 10:1.
Glen in TX
09-07-2005 21:16:25
 Re: Impulse on Mag in reply to jd b help, 09-07-2005 19:48:40
Yes, the impulse is adjustable. First your mag impulse should have a crisp fast trip to it. If not the impulse spring could be broke or weak or impulse parts worn or even bushings out on the Wico C not letting it trip right. Also some early Wico Cs were known to have the bushing tubes come loose in housing. If all that checks out well and not too much slack in shaft check the marks on back inside for impulse setting. Most were setup at 35 degrees for oil fuels and you can change it to 25 degrees for gasoline. You want the mark on the impulse stop plate to the LEFT of center housing mark about 2 1/2 marks for 25 degrees. The center housing mark is 13 degrees and each mark to the left or right is another 5 degrees. If for some reason your C mag has the drive cup from a X mag on it like the 6274 drive cup you may have to set it at 4 1/2 marks to the left or somewhere in between to get 25 degrees. When the 6274 short lug drive cup is used on the X mag the center mark becomes 3 degrees. Have the points clean and flat and set at .015" and hopefully you'll have a nice blue spark when impulse trips.
Duane Larson
09-07-2005 21:10:17
jd b help,
It sounds like your impulse unit is working correctly. When you turn it by hand it fires at TDC. The impulse dogs are designed to drop out at about 225-250 rpm, at which time the spark time changes from TDC to 25-35 deg before top dead center depending on the drive cup you are using on the magneto. Apparently you are pulling it too fast and the impulse is spinning fast enough to drop out. Try pulling it slower.
With a compression ratio of 10:1, you obviously have done some modifications to the engine and perhaps should consider going to a Delco Remy 1111558 distributor and external coil. Also check the starter ring on the flywheel for worn teeth. What year and model tractor is this?
jd b help
09-08-2005 10:33:43
 Re: Impulse on Mag in reply to Duane Larson, 09-07-2005 21:10:17
Duane:
5.125 pistons. 7 inch stroke. It's a 44 JD B. Starter won't crank it over so I was forced to pull start it. Can't pull it any slower. I have a compression release setup being built today. Will try that tonight and see if that helps. Holds the exhaust valve slightly open.
Glen in TX
09-08-2005 17:29:19
 Re: Impulse on Mag in reply to jd b help, 09-08-2005 10:33:43
Another high compression puller. Nope the regular mags aren't adjustable from the outside for what you are wanting to do. You'll either have to move the mag when starting it and then move it back again after started OR go with a custom built mag with adjustable advance and retard OR go the distributor ignition route. 4 cyld. mags with the adjustable advance and retard can be grounded out on 2 cylinders off the cap and made to run a JD but cap and impulse drive has to be made to work and then advance and retard mechanism changed to allow 20 to 40 degrees adjustment. Your compression release might be a better way to go.
