1944 B Flywheel moves outward
jd b help
09-07-2005 17:28:06
Anybody have any tricks to getting that flywheel to stay where it is supposed to? Put together a stroker motor and the flywheel keeps wanting to slide out. Any advice is welcome. Thanks
Skyhawk Greg
09-08-2005 08:44:05
 Re: 1944 B Flywheel moves outward in reply to jd b help, 09-07-2005 17:28:06
JD B - Make sure the splines are clean on both the shaft and the flywheel, and that there is no oil residue. MEK works well for degreasing. Also, how are you tightening the nuts? I have found that the best way to tighten them is to use the JD flywheel wrench. Even when using universal joints, it seems you can't torque the bolts as well as with the correct wrench. I have broken universal joints, and still not achieved the proper torque. The special wrench is worth the money in my opinion. There is one made for hand start B's, and one made for the electric start B's. The one for electric start will work on both types. Re-torque the nuts after a few minutes of running, and then periodically after that. Pretty soon, it should stay on.
jd b help
09-08-2005 08:54:11
 Re: 1944 B Flywheel moves outward in reply to Skyhawk Greg, 09-08-2005 08:44:05
Gregg: I am torqueing it with a 1/2" ratchet and 2 foot pipe extension. Silly me, I had applied some grease to the spline so it would slide easier. I never made the connection... I also got two new bolts/nuts/washers from JD this morning and will try again. I'll take some degreaser to it as well. It is moving outward about 1/16-1/8" within a few minutes.
Thanks for yours and everyones' help.
jd b help
09-07-2005 19:42:40
Thanks Duane and Mike. I was just about to fall asleep and I thought "I wonder if I should get new bolts?". Then I saw your post and thought "yep". Thanks.
Duane Larson
09-07-2005 19:24:14
jd b help,
You probably would also benefit from a new set of flywheel clamp bolts. I believe Correct Connection sells them - square head, grade 5, oversize hex nut, same size as you now have. Your old bolts have probably stretched, resulting in less clamping ability.
Mike M
09-07-2005 19:14:32
Most of the pullers I see drill and tap the end of the crank and make a big steel washer to bolt on to hold them from walking out.
