650 JD
Bobmn
09-07-2005 17:18:40
Hi Guys; Can anyone tell me about a 1990 JD 650? I know it's a 2cyn.diesel, 3pt,hyds,mow deck,rear blade,low hrs.I think Yarmar made them to JD specs. I am looking at one from a pvt. party. Thanks much, Bob
leon
09-07-2005 18:13:18
 Re: 650 JD in reply to Bobmn, 09-07-2005 17:18:40
As a rule, these were indeed good little reliable tractors. Yes' they were made in Japan by Yanmar, after a good deal of input from Deere regarding their design. It has a 80X85mm BXS engine (52 Cu in) rated at 2600 rpm. It has an 8F/2R sliding gear transmission. On the pto, it has 14.5 hp. Net engine is 16 hp. Shipping weight is 1593 in 2WD and 1714 lb in MFWD, which I highly recommend, especially if you're planning on using a loader with it.
Bobmn
09-08-2005 06:18:39
 Re: 650 JD in reply to leon, 09-07-2005 18:13:18
Leon; Thank you so much for the information! I have a bunch of BIG tractors, but not up to date on the 6 to 9 hundred series. Again, thanks, Bobmn
