4020 hydro filter cover
Nylon
09-07-2005 12:00:38
I called yesterday tractors for a filter cover that is ported. They had nothing showing for the 4020 and I also requested a look at the 2640 filter cover. Nothing again. That 2640 cover will fit on 4020? I read other posts in a search and gerald j had suggested it would work. Apparently the factory ports have a baffle so the return oil doesn't jet cut the filter.
My close JD Dealer is 80 miles away. He also is not too keen on shipping anything and I am not keen on driving 80 miles everytime I need a small part.
You guys suggest a source for this ported filter cover? Or another safe alternative for a return oil?
Thanks,
John
Pete/ME
09-08-2005 02:50:58
 Re: 4020 hydro filter cover in reply to Nylon, 09-07-2005 12:00:38
It's not much help I know, but I got my ported cover from my JD dealer. I told the parts guy how I wanted remotes for my Kelly 56 that by-passed the SCV's and he brought out a cover. This just says that JD has the part. (About $60 I think.) I think a good parts guy could help you, if not, let me know and I'll try to get the part #.
msb
09-07-2005 20:37:25
Nylon, you could do like we did before that ported cover became avaiable.I simply drilled the outer edge of the cover and brazed in a pipe nipple.Did a bunch of them and never had one to fail.
masterwelder
09-07-2005 17:16:00
John, I can fabricate just what your looking for. I just need to know what fitting you would like to have and where placed. The fitting will be tig welded along with a baffle to deflect return oil flow. Then we will UPS it right to your door.
Nylon
09-08-2005 20:53:18
 Re: 4020 hydro filter cover in reply to masterwelder, 09-07-2005 17:16:00
Masterwelder,
Did you get my e mail?
John
Nylon
09-07-2005 12:07:47
Mike,
Did this essentially dump the oil back into the reservoir? Which then got sucked into the sump screen and then the filter? I had asked my jd dealer about doing this a while back and my memory is thin but I believe they said they tapped a T into the rockshaft return oil. I do want to dump return oil into a place where it goes to reservoir then screen then filter to be safe. I cant tell exactly where the rockshaft return oil is or if it is internal.
RickB
09-07-2005 14:32:44
 Re: 4020 hydro filter cover in reply to Nylon, 09-07-2005 12:07:47
The idea is to return the oil to a spot where it can be filtered and readily available to the front pump without having to pass through the rear charge pump. The return flow PLUS the charge pump flow then have a fighting chance to supply the front pump a sufficient volume of oil to allow it to pump near its capacity for longer periods of time. If all oil supplied to the front pump has to be pumped by the charge pump, the front pump will cavitate under sustained high flow demand.
Doug in RKPT
09-07-2005 15:43:29
 Re: 4020 hydro filter cover in reply to RickB, 09-07-2005 14:32:44
i DILLED A HOLE AT AN ANGLR AND THEN BRAIZED A FITTING TO MAKE MY RETURN LINE. bEEN RUNNING LAST 4 YEARS NO PROBLEMS.
