G carb on A? Baker Valve?
Oliver Colterya
09-07-2005 10:56:58
Has anyone used a G carb on an A? More hp? Also, does anyone know where to get rebuild kits or parts for the Baker valve? Thanks.
Hayfarmer
09-07-2005 19:14:59
 Re: G carb on A? Baker Valve? in reply to Oliver Colteryahn, 09-07-2005 10:56:58
I don't think anyone has a rebuild kit for a Baker valve. I also don't think there is anything too complicated in there you couldn't get from a tractor or hydraulic supply place, mostly o rings. What is the valve doing/or not doing?
Oliver Colteryahn
09-07-2005 22:00:34
 Re: G carb on A? Baker Valve? in reply to Hayfarmer, 09-07-2005 19:14:59
It was a question in preparation to remove the valve from a BW chassis and install it on my 51 AW. I haven't the foggiest idea how long this valve has been sitting, condition, etc, or even if it works. Thought it would be better to ask a question prior to starting the project. Thanks for your input.
jd b puller
09-07-2005 17:26:08
Bigger isn"t ALWAYS better. The DLT71 can flow a lot of air. If you don"t have a big motor, don"t mess with the G carb. My B is bigger than a stock A, runs more RPMs, and only has the DLT71 main jet open about 1.33 turns...
Too many people put too big a carb on and then run out of power if they lose RPMS. See the posting on the Tractor pulling page about the Farmall H running out of power.
Hope that helps.
Oliver Colteryahn
09-07-2005 22:02:22
 Re: G carb on A? Baker Valve? in reply to jd b puller, 09-07-2005 17:26:08
Yes, your input is helpful. Thank you.
JDBert
09-07-2005 13:19:30
If your A is a factory gas model you'll have a DLTX-71 carb, your probably not going to gain anything over that with a big nut carb. The big nut is a ALL FUEL carb, so unless you've done some engine modes you might even see less HP.
Connor D
09-07-2005 11:19:43
We are running a G carb. on a 51 A runs fine without a dyno. I don"t know about the horse power possibly a little more not much.
Oliver Colteryahn
09-07-2005 12:00:24
 Re: G carb on A? Baker Valve? in reply to Connor D, 09-07-2005 11:19:43
I thought it would be OK, glad to see your response, I was going to use the G carb on a 51 A also!
Glen in TX
09-07-2005 13:56:59
 Re: G carb on A? Baker Valve? in reply to Oliver Colteryahn, 09-07-2005 12:00:24
The DLTX-51 is listed as a gasoline carburetor in the JD SM2024 service manual charts. It could be set up with 2 different nozzles. Looking in bottom center if the brass nozzle is slanted on the end it is the later 47-649 nozzle made for gasoline. Without other modifications you won't get much advantage from it.
