3010 oil from rear main
BradB
09-07-2005 09:25:43
I had my 3010 rear main seal replaced and the clutch done last spring. Have been doing hay and plowing with it. I still have oil dripping from the inspection cover. I have checked the breather tube and it does not seem to be cloged up. I saw the new seal installed but, still have this oil dripping. Tolerances were also checked on the crank when it was apart. I do not like the oil drip! Have also been checking to make sure oil level is ok. Any thing I can do short of another seal? Thinking I would rather sell and buy a new JD.
msb
09-07-2005 20:58:26
 Re: 3010 oil from rear main in reply to BradB, 09-07-2005 09:25:43
Its very easy to damage the engine shaft seal that Bob talks about if the tech is not careful when rolling the two sections of tractor back together.He is right.Find out if it is hydraulic oil or engine oil.If your tractor is a diesel then it should be easy to tell where the oil is coming from.Those later rear main seals are very easily damaged if the correct installation procedure isn't followed to a tee.
I suppose it is possibe that old oil is dripping out the case if the tech didn't clean the bell housing out,but I can't imagine anyone being that sloppy. You can remove the inspection plate on the bottom and have a look inside.
G/MAN
09-07-2005 15:41:45
I agree with Bob. Make sure it's the rear main seal, although either way, it's going to have to be split to be repaired. Those new rear mains are pretty good seals, and it's pretty hard to screw one up if installing it with the correct tools in the correct manner. I'd be looking hard at the pan gasket where the seal retainer meets it also.
Bob
09-07-2005 13:53:56
Are you sure it's engine oil, and not hydraulic/transmission oil?
There is one seal at the front of the tranmission that can do this, plus 1 more between the shafts at the clutch, if the tractor is equipped with a PTO.
Mike M
09-07-2005 09:32:01
Did you ask if there is any warranty from who put it in ? The part should be covered a year.See if they will cover the labor. It could also be leaking from somewhere else like the tranny input ?
